fedetouz
i need eliminate characters <CR><LR> |
Posted: Thu Aug 16, 2007 4:53 pm |
Hi all, i have the respond of the gsm module like this:
<CR><LF>
170.51.251.112<CR><LF> |
i store this on buffer string, the problem is that i need eliminate CR and LF characters ,and send the numbers to other string.
I need some help
Thanks!
sorry for my english!!!
Fede |
Posted: Fri Aug 17, 2007 12:03 pm |
Quote: | I store this on buffer string, the problem is that i need eliminate CR and LF characters ,and send the numbers to other string. |
Is this a string ? Does it have a zero byte at the end, to make it a string ?
If so, then use the strlen() function to get the length of the string.
Then use a for() loop to step through each byte in the string, and
copy each one to another buffer. Inside the for() loop, read a char
from the first buffer, and use an if() statement to check if the char
is either a CR or a LF. If so, then skip copying that character to
the 2nd buffer. Also, when you finish copying the chars to the 2nd
buffer, make sure you write a zero byte at the end, so it will become
a string. |
fedetouz
Posted: Sat Aug 18, 2007 1:42 pm |
Thanks! PCM, i see all clear right now!, i try this now thanks again! |
