ds1307
reemy
ds1307
PostPosted: Sat Aug 18, 2007 5:10 pm     Reply with quote
hi
i'm new
i have exotic problem
i have rtc code using ds1307 on this page http://www.sixca.com/micro/pic/ds1307/
and here is my code
#include <18f4620.h>
#include <stdlib.h>
#fuses xt,NOWDT,NOLVP
#include <ds1307>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <INPUT>
   delay_ms(50);
   init_ds1307();          // initial DS1307
   sec=read_ds1307(0);
   write_ds1307(0,sec & 0x7F); // enable oscillator(bit 7 =0)
   write_ds1307(0,0x50); //sec
   write_ds1307(1,0x00); //min
   write_ds1307(2,0x01); //hr
   write_ds1307(3,0x01); //day
   write_ds1307(4,0x01); //date
   write_ds1307(5,0x01); //mnth
   write_ds1307(6,0x01); //year
   enable_interrupts(INT_RDA);
   ring_flag=0;
   //on_flag=0;
   f=0;
   while(1) {
//     value= read_eeprom(f);
//     printf("%X\r\n",value);
//     delay_ms(1000);
//value= (f%2);
//printf("%u\r\n",value);
//delay_ms(1000);
//     f++;
start:
    on_flag=1;
   while(on_flag==1){
      //if (clk_flag==1){
      dow = read_ds1307(3);   //Determine the daya of the week
      Add1=(dow-1)*36+1;      //Start address equation due to dow
      Add2=dow*36;
// printf("%u\r\n",dow);
//delay_ms(1000);
// printf("add1%u\r\n",Add1);
//delay_ms(1000);
// printf("add2%u\r\n",Add2);
//delay_ms(1000);
     hr_eeprom = read_eeprom(Add1);
 //    printf("hr_eeprom%x\r\n",hr_eeprom);
 //     delay_ms(1000);
 //     if (hr_eeprom==25)
 //        delay_ms(1000);
 //        goto START;
 //     }  //end if
 //     else
         hr = read_ds1307(2);    //Read the current hour
         min = read_ds1307(1);   //Read the current minute
        // if(min!=prev_min)
        // ring_flag=0;
       for (i=Add1;i<Add2;i+=2)
            j = i + 1;
            hr_eeprom= read_eeprom(i);
            min_eeprom = read_eeprom(j);
           //printf("hr_eeprom%x\r\n",hr_eeprom);
           // delay_ms(1000);
           // printf("min_eeprom%x\r\n",min_eeprom);
           // delay_ms(1000);
            if (hr_eeprom==hr)
               if( (min_eeprom == min) )
                 // ring(duration);
                 // min_ring = min_eeprom;
                 output_high(PIN_B0);
                 output_low(PIN_B0);
                 prev_min=min;
                 ring_flag=1;
                  goto START;
               } //if( (min_eeprom == min)&& (flag==0) )
               //delay_ms(500);
            }//if (hr_eeprom==hr)
         }  //end for
      //}  //end else
   }//on_flag
   }//while
   }//main
of course i have my declaration and use of int_rda to get data and save them in eeprom.
i do simulation using Proteus isis simulator and make sure that i get data correct and save them correct but problem occur in compare loop,simulation program cpu load is 93% and is very slowly and i cant see any simulation.why?is this problem in my code?i try to re install both Proteus and ccs compiler and still as it. it make normal simulation for one time and unfortunately i do it just for one byte of data its work fine but this dose not mean its will work for a block of data (i.e.100 byte and more)
regards,
reemy
PostPosted: Sun Aug 19, 2007 2:05 pm     Reply with quote
I do simulation using Proteus isis simulator and make sure that i get
any simulation.
If Proteus isn't simulating correctly, you should ask about it on the
Proteus forum at the link below:
http://support.labcenter.co.uk/forum/
