analog port configuration for 18F2620
starfire151
PostPosted: Sun Aug 19, 2007 5:21 pm     Reply with quote
I'm looking at the analog port configuration section of the CCS 18F2620 support file and the codes associated with selecting active analog input channels... The following is a snippet of the file:
// Constants used in SETUP_ADC_PORTS() are:
#define NO_ANALOGS 0x0F // None
#define ALL_ANALOG 0x00 // A0 A1 A2 A3 A5 B2 B3 B1 B4 B0
#define AN0_TO_AN11 0x03 // A0 A1 A2 A3 A5 B2 B3 B1 B4
#define AN0_TO_AN10 0x04 // A0 A1 A2 A3 A5 B2 B3 B1
#define AN0_TO_AN9 0x05 // A0 A1 A2 A3 A5 B2 B3
#define AN0_TO_AN8 0x06 // A0 A1 A2 A3 A5 B2
#define AN0_TO_AN4 0x0A // A0 A1 A2 A3 A5
#define AN0_TO_AN3 0x0B // A0 A1 A2 A3
#define AN0_TO_AN2 0x0C // A0 A1 A2
#define AN0_TO_AN1 0x0D // A0 A1
#define AN0 0x0E // A0
From the Microchip 18F2620 datasheet, the codes match from 0x0f, 0x0e, 0x0d, 0x0c, and 0x0b but the datasheet lists entries for AN4 (on pin 6 of the 18F2620) and the CCS doesn't seem to list any entries for the AN4. None of the rest of the codes seem to match.
I'm trying to set up for 8 analog inputs with a PIC18LF2620 or 18LF2525 device. Which code should I use and which pins will the analogs be input onto?
Thanks.
PostPosted: Sun Aug 19, 2007 6:31 pm     Reply with quote
Look at the PCFG-bits table in the A/D section of the 18F2620 data sheet:
ADCON1: A/D CONTROL REGISTER 1
PCFG3:PCFG0: A/D Port Configuration Control bits
For AN0-AN4 as analog, the table has the value of 0x0A.
Also note that AN5-AN7 are not available on the 18F2620. Microchip
places this note below the table:
2: AN5 through AN7 are available only on 40/44-pin devices.
