fedetouz
Problems with Microchip ICD2 Debug and 18F458 |
Posted: Thu Aug 23, 2007 10:09 am |
Hi, i have a problem with debug on ICD2, this is the config of the pic
#include <18F458.h>
#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=Xbee232)
CD0083: Debug: Unable to enter debug mode. Please double click this message for more information.
ICD0069: Debug: Unable to run target
in programing work ok, but the problem is on debug, the voltaje test its ok!.
Thanks for help! |
