how can i connect pic 18f458 with 2x16 serial lcd
jamelof23
PostPosted: Tue Sep 11, 2007 8:52 am     Reply with quote
hi,
how can i connect pic 18f458 with 2x16 serial lcd,
i dont know which pins i should connect to lcd
Confused
thanks in advance
PostPosted: Tue Sep 11, 2007 11:09 am     Reply with quote
How can I connect pic 18f458 with 2x16 serial lcd.
Use the "flex" driver in the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
I dont know which pins I should connect to lcd.
See this schematic. It shows two LCDs, with examples of the
connections. On one LCD, the data and control pins are split between
PortA and PortB on the PIC. On the other LCD, the data and control
pins all go to PortD. With the "Flex" driver, you can make it work
with almost any pins on the PIC.
http://www.trash.net/~luethi/microchip/datasheets/lcd/lcd_connectivity.pdf
Humberto
PostPosted: Wed Sep 12, 2007 10:28 am     Reply with quote
Serial LCD modules (RS232 conectivity) have not a standard wiring.
Tell us the manufacturer of your Serial LCD Module and we will help you better.
Humberto
