#ignore_warnings macro
jmac_link
PostPosted: Wed Aug 01, 2007 6:05 am     Reply with quote
Im trying to make a macro to ignore compiler warnings:
#define WHILE_TRUE #ignore_warnings 203 while (1) { #ignore_warnings NONE
#define END_WHILE_TRUE }
WHILE_TRUE
   do_something()
END_WHILE_TRUE
I get compiler error:
'Constant out of the valid range 0 is not 200..299'
for #ignore_warnings 203
(Ive also tried separating lines in the macro using \)
Is it that #ignore_warnings wont allow anything else except the warning number after it => this macro idea is doomed?
Thanks in advance,
John Mackenzie
jmac_link
PostPosted: Wed Aug 01, 2007 6:11 am     Reply with quote
Forgot -compiler version is 3.249
kevcon
PostPosted: Wed Aug 01, 2007 7:21 am     Reply with quote
try putting a semicolon after do_somthing( )
PostPosted: Wed Aug 01, 2007 7:24 am     Reply with quote
while (1)
is equivalent to
for(;;)
The latter doesn't generate a compiler warning.
If you don't like the for-loop construction you could write your DO_WHILE macro as
#define DO_WHILE  for(;;) {
jmac_link
PostPosted: Wed Aug 01, 2007 7:41 am     Reply with quote
Thanks ckielstra,
I never use for(;;) so hand't thought of using it!
Nice solution!
Very Happy
Mark Weir
Warnings
PostPosted: Thu Aug 02, 2007 1:41 pm     Reply with quote
Why not just use # ignore_warnings 203,202 etc
As a pre processor directive.
Cheers
Mark
Life is too short to avoid asking questions
Fusillade
Re: Warnings
PostPosted: Fri Aug 10, 2007 2:50 pm     Reply with quote
Cheers
Mark
He just wanted to replace:
while (1)
with:
WHILE_TRUE
which would clean up his code, would easily port to other programs, and it would disable the warning 203 for the "while (1)" only.
It appears to be doomed as the #ignore_warnings won't allow anything else except the warning numbers and commas after it. This includes comments.
It took me a bit to figure out why the following line continued to give me the same error as John:
#ignore_warnings 203 // ignore the warning for while(TRUE)
jmac_link
Re: Warnings
PostPosted: Mon Aug 13, 2007 2:43 am     Reply with quote
while (1)
with:
WHILE_TRUE
Exactly!!
In the end I used for(;;) instead because
a) #ignore_warnings doesnt allow anything after the number(s) on the same line
b) its cleaner.
