MarcosAmbrose
Joined: 25 Sep 2006 Posts: 38 Location: Adelaide, Australia
Even Parity - Manipulating the 9th bit |
Posted: Mon Aug 13, 2007 10:25 pm |
Compiler: PCWH 3.249.
Device: 18F6722
Hi All, I'm using a 18F6722 to talk to a device at 2400bps with even parity.
By opening up the UART in 9 bit mode (see code below) I can reliably recieve data with parity.
Code: | #use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9,Stream=PC)
#int_RDA
RXData()
while(kbhit(PC))
RX_Buffer[InPointer++]=fgetc(PC);
When I transmit data however, if the data contains an even number bits the transmitted data is correct. If however the data contains an odd number of bits, the UART (or putc) pre-pends an 0x3F followed by the data. E.g
Code: | fputc(0x03,PC); //UART TX's 0x03
fputc(0x02,PC); //UART TX's 0x3F,0x02 | I'm guessing this has something to do with the 9th bit.
Has anyone else encountered this before. I suspect I have to somehow manipulate the 9th bit in the UART to keep the parity correct. If anyone has any thoughts or ideas on this I'd be gratefull to hear them.
-Cheers |
Posted: Tue Aug 14, 2007 5:13 am |
The simple answer, is set the use statemnt up properly for what is wanted at the other end...
02 send receive 7bit e 7bit o 7bit n 8bit e 8bit o 8bit n
7bit even 10010000011 02 02(*) 02 82 82(*) 82
7bit odd 10010000001 02(*) 02 02(1) 02 02 02(*)
7bit no 10010000011 02 02(*) 02 82 82(*) 82
8bit even 100100000011 02(*) 02 02(!) 02 02(*) 02
8bit odd 100100000001 02(!)3F 02(*) 02(!) 02(*) 02 02(!)
8bit none 100100000011 02(*) 02 02(!) 02 02(1) 02
Hopefully this will display correctly, but if not, cut and paste it into notepad, using a fixed pitch font.
Hopefully I have got these right...
Now the left hand column, gives what format is being sent. Then the binary pattern generated, then what is received in a number of different formats. The entries marked '*', will have a parity error a the receiving end, while those marked '!', will have a framing error. Note in particular, what is received, by a system expecting 7bits even parity, if you send data using 8bits odd parity, to a system expecting 7bits even parity. Note that this is exactly what is sent, if you select 9bit mode, with the 9th bit set to zero (which since you are not setting it, it is...).
So if you change the use RS232 statement, to:
#use rs232(baud=2400,parity=E,xmit=PIN_C6,rcv=PIN_C7,Stream=PC)
It should start working.
