Please help with ADS7825 16-bit ADC
akokyaw
PostPosted: Thu Jul 05, 2007 7:17 pm     Reply with quote
I have read back problem with ADC7825 which is 16-bit ADC, bipolar 10V. After interfacing with this chip, the read back values are as follow:
For -10V to 0 -> the read back value = 0 to 65536
For 0V to +10V -> the read back value = 0 to 65536
The problem is how to identify the polarity of input voltage? According to datasheet, the format of output is Binary Two's Complement. Please help me.
Thank you,
ako
PostPosted: Thu Jul 05, 2007 8:15 pm     Reply with quote
Two's complement means it's a 'signed' number. When you write the
software driver for the ADC chip, you need to make the 'read' function
return a 'signed int16' value. Then, when you use printf to display it,
you need to specify the %LD format. This will display a signed int16
number.
For example, the following code shows how to return a signed int16
value from your 'read' function.
signed int16 read_ADC7825(void)
signed int16 retval;
// Put the rest of the function code here.
return(retval);
akokyaw
ADS7825 16-bit ADC
PostPosted: Fri Jul 06, 2007 5:55 am     Reply with quote
Thank for reply, PCM programmer
I have tried signed int16 variable for read back value. The followings are what I got:
For -10V to -5V -> the read back value = 0 to 32768
For -5V to 0V -> the read back value = -32768 to 0
For 0V to +5V -> the read back value = 0 to 32768
For +5V to 0V -> the read back value = -32768 to 0
Do I have to do hardware detection to polarity of input voltage?
Please indicate where I miss something. Any suggestions or comments would be appreciated.
Thanks,
ako
nina
ADC
PostPosted: Fri Jul 06, 2007 7:16 am     Reply with quote
hi akokyaw
could you post your code, please.
tks
nina
KASMO
HELP
PostPosted: Sat Aug 04, 2007 10:27 pm     Reply with quote
HI, I'M also trying with ads7825 , but i'm novice in this devices , you'r using a serial configuration ? ,, and , however the case , can you post your code (i believe you'r using ccs c compiler),please and thanks for your help
RM
16bit adc
PostPosted: Sat Aug 11, 2007 2:39 am     Reply with quote
Can u post ur code
