CCS Bootloader - programming Bootloader AND application?
cyberant
PostPosted: Thu Aug 09, 2007 2:12 am     Reply with quote
Hello Smile
I use the CCS Bootloader - which works fine.
But is there a way to modify it so that you can programm the bootloader and the programm in one step via a programmer Question
So that if I programm the Bootloader I have the application included and can then change the first programmed application via RS232 but not the bootloader.
Can I simply include my main.c into the bootloader at a location where it can get overwritten by a new programm version via RS232 or somthing like that?
PostPosted: Thu Aug 09, 2007 3:13 am     Reply with quote
This is possible. In ex_bootloader.c replace application() by an include of your main.c. You will also have to rename your main() to application(), or even better make this dependent on the _bootloader being defined.
Another option that looks promising but I haven't tried yet is to create the bootloader and your application as seperate programs (but at the correct final program addresses) and then combine these two afterwards if needed.
Merging two applications into one Intel Hex file
