ds1307 + int_rda
hadeelqasaimeh
ds1307 + int_rda
PostPosted: Sat Aug 11, 2007 5:10 pm     Reply with quote
hi
when i use ds1307(real time driver) may this affect rs232 intterupt (rda) work?i mean is any one of them disable the other???
PostPosted: Sat Aug 11, 2007 10:06 pm     Reply with quote
At least one of the ds1307 drivers that is posted on this forum does
disable global interrupts during the i2c operations, so yes, it would
affect the #int_rda.
hadeelqasaimeh
PostPosted: Sun Aug 12, 2007 7:05 am     Reply with quote
hi PCM programmer
i use the driver in the following link:
http://www.sixca.com/micro/pic/ds1307/
i must receive time serial from pc such as
hr
min
hr
min
and so on
pic take these times and write them to internal eeprom,i try to do code and it work for one time.then stop
what can i do??
PostPosted: Sun Aug 12, 2007 1:59 pm     Reply with quote
I use the driver in the following link:
That driver doesn't disable global interrupts. So that's not the problem.
Imust receive time serial from pc such as
hr
min
hr
min
pic take these times and write them to internal eeprom, i try to do code
and it work for one time. then stop
Add the ERRORS parameter to your #use rs232() statement.
hadeelqasaimeh
PostPosted: Sun Aug 12, 2007 2:04 pm     Reply with quote
thank you very much Smile
