Access violation at address 007971c8 in PCW.exe
jventerprises
PostPosted: Thu Aug 09, 2007 9:38 am     Reply with quote
this just started with the latest version 4.049. when the debugger is disabled all is fine. when i enable the debugger i cant access any of the menu pulldowns, or right click on the source to set breaks, etc. although the buttons in the debugger (step/reset,etc) all work. disable the debugger and all is ok.
i did a complete un-install (including the registry keys) and re-install, but it didnt help. the last version was fine...
i also noticed a firefox browser auto-update around the time this started, any thoughts?
anybody else getting this message?
i filed a bug with CCS and they are looking at it.
Jon
Ken Johnson
PostPosted: Thu Aug 09, 2007 2:43 pm     Reply with quote
Yes, I have the same problem, and have contacted CCS.
This also happens if you try to open a new project with the debugger window open.
Sure hope they fix it soon !
Ken
Pret
PostPosted: Fri Aug 10, 2007 12:54 am     Reply with quote
Try set the font to bold in editor properties and restart pcw. That's a challenge...
jventerprises
setting bold in editor
PostPosted: Fri Aug 10, 2007 8:21 am     Reply with quote
setting bold in the editor preferences and restarting ends very badly! i wonder if its all releated.... (i just removed the bold=1 from the .ini file to fix it)
i also had a similar problem when i changed the editor font from the default. i could set break points, but could not clear them!
Jon
millig
PostPosted: Fri Aug 10, 2007 9:29 am     Reply with quote
I had the same problem. Changed to classic view and all is working well....so far. I'm not sure, but I think it is a bug related to Vista and XP compatability. (I'm usuing XP).
