Dominik
Problem with LCM-SO1602DTR/M LCD on Picdem 2 Plus Demo Board |
Posted: Sat Aug 04, 2007 7:37 am |
Hello
I have a problem with the LCD display on the Picdem 2 Plus Demo Board 2006.
I can't display anything using the lcd.c driver that I tried to update or other programs I found at here as lcdd.c.
The pin connection is as follows:
D0 D4
D1 D5
D2 D6
D3 D7
D4 rs
D5 rw
D6 enable
D7 power
If someone has a working driver or has any idea to help me it will be very welcome.
Thank you
Best reards,
Dominik |
Posted: Sat Aug 04, 2007 11:54 am |
There are two threads on this.
In this thread, we discover that the LCD's "busy" bit doesn't work,
on at least on some of the "Rohs update" PicDem2-Plus boards.
http://www.ccsinfo.com/forum/viewtopic.php?t=29768
In this thread, the person says it was only necessary to turn on
power to the LCD, and then it worked.
http://www.ccsinfo.com/forum/viewtopic.php?t=29521
I still don't have one of the new "Rohs update" boards.
Here is what I believe you should do:
1. Use the "Flex" lcd driver at this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
2. Change the pin list at the start of the driver, so it uses these pins:
#define LCD_DB4 PIN_D0
#define LCD_DB5 PIN_D1
#define LCD_DB6 PIN_D2
#define LCD_DB7 PIN_D3
#define LCD_E PIN_D6
#define LCD_RS PIN_D4
#define LCD_RW PIN_D5
3. Comment out the line which tells the driver to use the R/W pin
on the LCD. This line is just below the pin list in the driver.
Code: | // #define USE_LCD_RW 1 |
4. Try this test program:
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define LCD_POWER PIN_D7
#include "Flex_LCD.c"
output_high(LCD_POWER); // Turn on power to LCD
output_low(LCD_RW); // Set R/W pin on LCD to a low level
lcd_init(); // Initialize the LCD
lcd_putc("Hello World");
There is no guarantee that this works, because I don't have the new
"Rohs update" version of board. |
Dominik
Posted: Sat Aug 04, 2007 1:45 pm |
Thank you Mr PCM Programmer
I've tried your test program including the flex_LCD with the update you said and it's working !
The only problem remaining is that there's a strange character displaying on the LCD just after the characters that I want to display.
Kind regards,
Dominik |
Posted: Sat Aug 04, 2007 2:13 pm |
Post a test program that shows the problem. Make it be similar
to the one that I posted, but have it show your problem. (Keep it small). |
Dominik
Posted: Sat Aug 04, 2007 2:27 pm |
The program I used is the one you sent to me :
#include <16F877.h>
int x = 1;
lcd_putc("Hello");
And what is dsiplayed on the LCD is ---> Hello† |
Posted: Sat Aug 04, 2007 2:41 pm |
Does your PIC have a 4 MHz crystal ? |
Dominik
Posted: Sat Aug 04, 2007 2:46 pm |
The Quartz is the one on the Picdem Board ---> JWT 4.00/5V MHZ and the PIC I'm using is a 16F877A |
Posted: Sat Aug 04, 2007 3:13 pm |
Quote: | The Quartz is the one on the Picdem Board ---> JWT 4.00/5V MHz
and the PIC I'm using is a 16F877A. |
You need to change the include file so it's for the 16F877A instead of
the 16F877. Example:
Code: | #include <16F877A.H> |
Dominik
Posted: Sat Aug 04, 2007 3:28 pm |
I've changed the line :
Quote: | #include <16F877A.h> |
But I still have the character after.
The PIC I'm using is a PIC16F877A-I/P if it can help |
Posted: Sat Aug 04, 2007 3:43 pm |
Try adding an additional delay after applying power. There's already
a delay statement in the Flex driver's init_lcd() routine, but maybe it's
not enough. Add the line shown in bold below, in exactly that position:
If this doesn't work, I'll look at it some more tomorrow. At that time
I will be able to look at the LCD data sheet and sample drivers from
Microchip and the LCD manufacturer, that I have on my PC at work. |
Dominik
Posted: Sat Aug 04, 2007 4:08 pm |
I tried by adding :
at the place you said but the character is still displaying.
So let's see that tomorrow but anyway thank you so much for your help !
Best regards,
Dominik |
Posted: Sat Aug 04, 2007 4:41 pm |
Also, post your compiler version. It's a 4-digit number in this format x.xxx
and you can find it at the top of the .LST file, which is in your project
directory. Don't post any numbers that come after the version number. |
Dominik
Posted: Sun Aug 05, 2007 1:14 am |
The version I found in the LST file is :
CCS PCM C Compiler, Version 4.013 |
Posted: Sun Aug 05, 2007 2:54 pm |
That's an early version. It's possible that it's causing a problem, but it
may not be. I briefly compared the .LST files between vs. 3.249 and
4.014 (don't have 4.013) and I didn't see any differences in the areas
where I looked. I don't have time to look at all of it.
I'm trying to think of what could cause an extra character at the end
of a line.
1. It's possible that the LCD control lines are being left in some
indeterminate state, and somehow this causes a bad extra character.
2. Perhaps the LCD power pin is being glitched at the end of the
string, for some unknown reason, and this causes a bad character.
3. Perhaps the compiler isn't properly detecting the "end of string"
in the "Hello" string, and is sending a garbage character at the end.
4. The "busy" delay in the lcd_send_byte() routine may be too low.
5. The initialization bytes in the Flex driver not be exactly correct
for this LCD.
6. It's possible that you didn't do all the changes that I said in an earlier
post, such as commenting out the "#define USE_LCD_RW 1" line
in the Flex driver.
7. It may be that you're running a different test program than the one
that you posted. I may not be looking at your real program, and
therefore, I can't see the actual problem.
Let's try an experiment, assuming that it's item #4. Edit the Flex_lcd.c
driver, in lcd_send_byte() routine. See the line shown in bold below ?
Increase it to a much larger value, such as 500 us. Re-compile, and
re-program, and see if it helps.
Quote: |
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_RW_PIN
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60); // Try increasing this to 500.
If that doesn't work, try another experiment. Instead of sending a
string, send individual characters.
Instead of doing lcd_put("Hello"), break it up into individual putc()
statements, with delays in between, and with a large delay at the end.
See if you still get that 't' character. If you do, does it appear after
the 5 second delay at the end ?
lcd_putc('H');
lcd_putc('e');
lcd_putc('l');
lcd_putc('l');
lcd_putc('o');
delay_ms(5000);
Can I ask where you got the Rohs version of the PicDem2-Plus ?
You don't have to tell me. But if I knew where I could order one
and be guaranteed that I would get it (and not get the old version),
then I'd order one. Then I could fix this problem. 'Cause right now,
it's just shooting in the dark. Doing this by remote control just doesn't
really work. |
Dominik
Posted: Sun Aug 05, 2007 3:49 pm |
I've updated the compiler's version to the :
CCS PCM C Compiler, Version 4.038 and now I don't have no more that character problem with that program.
But I have one when I want to display a value as below:
char x;
x="Hello";
lcd_putc(x);
I don't have the value displaying on the LCD but only the character that I have before when I was using the 4.013 version.
This might becoming of that lastest Demo Board that I have bought at Microchip Direct Part Number DV164006. |
