cyberant
Timer0 does not work with Internal Oscillator |
Posted: Fri Aug 10, 2007 8:32 am |
My Timer0 worked with an external osci. - then I changed to an internal one and my Time Variable "tenthOfSeconds" is always 0
Can someone help me?
#include <18F4525.h>
#device adc=10
#fuses INTRC_IO
#FUSES H4 //4xPLL --> 8MHz*4 = 32MHz
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES PUT //No Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)//RS232 Initialisieren
#include "meinbootloader.h" //Bootloader (works)
unsigned long int_count=0;
unsigned long tenthOfSeconds=0;
//(timer0)
#int_rtcc
void clock_isr() {
if(--int_count==0)
++tenthOfSeconds;// = 1/10 seconds
int_count=12; //(32000000/(4*256*256))/10 = 12
//TIMER:
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256); // Timer0
setup_timer_1(T1_DISABLED); // Timer 1
setup_timer_2(T2_DISABLED,0,1); // Timer 2
//INTERRUPTS
setup_oscillator(OSC_32MHZ|OSC_INTRC|OSC_PLL_ON);//32MHz
enable_interrupts(RTCC_INTERNAL);
set_timer0(0);
while (true)
printf("%Lu",tenthOfSeconds);
disable_interrupts(RTCC_INTERNAL);
Posted: Fri Aug 10, 2007 8:52 am |
Get rid of the H4 fuse. This is incorrect when using the internal oscillator. Change the #use delay statement, to 32000000.
With the internal oscillator, the PLL is accessed differently (it has to be turned on in the code, not through the fuses). Selecting 32MHz in the use delay, will automatically tell the compiler to do this. At present, the code is only running at 8MHz. What is happening, is that because the PLL bit is 'on' in the fuses, it no longer works with the internal oscillator, so the chip is ignoring the PLLEN bit in the oscillator setup, and is running at the 8MHz used in your delay statement, which allows the serial to work. The 'delay' statement, must _always_ match the actual speed the chip is being clocked at.
Then set int_count to 1 or greater in the initialisation, or move the decrement to after the variable in the ISR.
Because it is '0', and the first thing the interrupt handler does, is decrement it, it'll 'wrap round', and go to 65535. With the oscillator running at 1/4 the expected rate, it'll take 26 thousand seconds to ever reach zero, and start counting (about 7 days)...
cyberant
Posted: Mon Aug 13, 2007 12:47 am |
OK, I try'ed your suggested changes - but now it displays crap via RS232
My new Code:
#device adc=10
#fuses INTRC_IO
//#FUSES H4 //4xPLL --> 8MHz*4 = 32MHz
#use delay(clock=32000000)
unsigned int int_count=1;
unsigned long tenthOfSeconds=1;
//(timer0)
#int_rtcc
void clock_isr() {
if(--int_count==0)
//TIMER:
//INTERRUPTS
set_timer0(0);
while (true)
With " #use delay(clock=8000000) " it displays endless 0
why does this not count up?
and why do the 32MHz not work? |
Posted: Mon Aug 13, 2007 1:32 am |
Quote: | With " #use delay(clock=8000000) " it displays endless 0 | You initialize tenthOfSeconds to 1, so it is very strange a constant value of 0 is printed. What is your compiler version?
There is also an error in your timer0 setup. By default this timer for your chip is 16bits wide but in your timer calculations you assume an 8 bits width. Either add RTCC_8_BIT to the setup_timer0() call or remove the RTCC_DIV_256. |
cyberant
Posted: Mon Aug 13, 2007 2:06 am |
Oh I mean it endless displays 1.
My Compiler version is 4.032 - is there a bug?
But why does my timer not count up????? (Ive removed the RTCC_DIV_256 but nothing changed)
EDIT:
OK Ive found out why my interrupt doesn't fire:
I have to use:
enable_interrupts(INT_RTCC);
instead of:
then my counter counts up.
But I still have the problem that it only runs at 8MHz.
If I change " #use delay(clock=8000000) " to 16MHz or 32MHz only crap gets received...
How can I setup 16 or 32MHz? (normaly i only have to change the delay or?)
Compiler bug in 4.032 ? |
