cyberant
| Problem with ccs bootloader |
Posted: Mon Jul 30, 2007 7:01 am |
Because i didn't find a bootloader for my pic 18f4525 i tryd the CCS one, but it didn't work - whats wrong with my code??
(I have a jumper on D7 which enables programming)
#include <18F4525.h>
#device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
//auf keinen fall XINST enablen - wird vom compiler nicht unterstützt
//#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOMCLR //Master Clear pin used for I/O
//Teil fuer RS232
#use delay(clock=12000000)
#define _bootloader
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+2,LOADER_END+20
void application(void) {
while(TRUE);
#org 0x40,0x7F
void main(void) {
if(input(PIN_D7))//if D7 high
load_program();
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
Then I send the CCS testprogramm with SIOW:
#include "main.h" //fuer Kunfiguration PIC - z.B.RS232 oder I2C
void main(void) {
int i=0;
printf("\r\nApplication program version 1.00 \r\n");
printf("%u ",++i);
Whats wrong? Nothing happens after I send the bootload file  |
cyberant
Posted: Mon Jul 30, 2007 8:03 am |
OK i found it - nothing wrong - I used open file to send the hex file via SIOW but it only works with "download Software".
Does anyone know how to send the hex filie the same way as SIOW sends it with "download Software" via hyperterminal? |
jma_1
Posted: Tue Jul 31, 2007 6:16 am |
Greetings,
Hyperterminal -> Transfer -> Send Text File
Hyperterminal is not as nice as SIOW and does not support non-standard COMM ports.
Cheers,
JMA |
cyberant
Posted: Tue Jul 31, 2007 3:34 pm |
Thanks - it worked - but now I have the Problem that if I send a larger File via Hyperterminal it does not finish transfering. Via SIOW it works without problems. With the small testfile Hyperterminal transfers completely and the Programm works but if I send a larger one it doesn't stop transfering?? strange...
(Ive waited 10 mins and via siow it finishes in ~1 min) |
jma_1
Posted: Tue Jul 31, 2007 3:50 pm |
Greetings,
If you notice with SIOW, when loading software the PIC responds with an ACK sequence after correctly receiving each record of the hex file. The source file says it also uses XON / XOFF flow control -> putchar(XON) and putchar (XOFF). Both of these are probably causing Hyperterminal to pause when sending the file.
Try changing the setup of the serial port in Hyperterminal to incorporate the flow control when sending the file. Alternately, use a different program like TeraTerm http://hp.vector.co.jp/authors/VA002416/teraterm.html
Do you need to use Hyperterminal? It's a quirky program at best. CCS recently started advertising a redistributable version of SIOW which might work for your situation?
Cheers,
JMA |
