How to access the 24LC256 simeltaneously using 2 pics ?
arunb
PostPosted: Tue Jul 31, 2007 8:02 am     Reply with quote
Is it possible to access a memory like the 24LC256 from two PICs.
I need to implement a system that logs data and also sends the data to a PC simultaneously (or almost)....
thanks
arunb
treitmey
PostPosted: Tue Jul 31, 2007 8:10 am     Reply with quote
I have done it with a I2C RIC FM24C04 Fram.
It was used by 2 16F877a,within 6" of each other, running off the same clock and power.
I think I would be possible with any I2C.
I had an extra pin to both pics with a pull-up to indicate
the chip was in use. ie: pull the pin down before using the eprom.
Don't "double up" the pull-up resisters. 1 on sda and 1 on scl should do.
rnielsen
PostPosted: Tue Jul 31, 2007 8:46 am     Reply with quote
You're, simply, talking about a multi-master system. Each master will be able to talk to any I2C device on the bus, just not at the same time. They'll each need to take control of the I2C bus and take turns. Read up on how multi-master setups work and have fun experimenting.
Ronald
