USB and Speed
LetThereBeLight
USB and Speed
PostPosted: Fri Jul 27, 2007 6:55 am     Reply with quote
Hi every one
I have a little trouble with USB and speed.
First i use HID demo program to build my own USB program.
we can reed in description :
//// - On a full speed device, max polling rate is 1 transaction     ////
////   per 1ms. This is 64000 bytes per second (64 byte packets      ////
////   every 1ms).
but also in HID descriptor :
 //endpoint descriptor
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==35
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==36
         0x01, //endpoint number and direction (0x01 = EP1 OUT)      ==37
         0x03, //transfer type supported (0x03 is interrupt)         ==38
         USB_EP1_RX_SIZE,0x00, //maximum packet size supported                  ==39,40
         10 //polling interval, in ms.  (cant be smaller than 10)    ==41
so wich one is right ? 10 or 1 ?
So HID is limited to 64*1000 bytes / s , that is pretty slow !
Also i am looking for a ISOCHRONOUS exemple to reach USB2 speeds .
Any one could advise me anything helpfull ?
thank you all.
