tkidder
testing a bit in a byte array |
Posted: Fri Jul 27, 2007 1:20 pm |
I am working on an industrial application using 18f4520. On every encoder pulse a bit is shifted into an array of 500 8bit integers, either a 1 indicating an error or a 0 indicating no error. On each pulse i check if a bit is set at a particular bit position in a byte
int8 sr[500] ;
if(!GError)
shift_right(sr,500,0);
shift_right(sr,500,1);
if(bit_test (sr[BytePos],BitPos)==1)
output_high(Kick);
The problem seems to be in the bit_test. The manual says you can only use bit_test on a variable. |
Posted: Fri Jul 27, 2007 1:57 pm |
1. Post a more complete test program, where you show all the variable
declarations and all #define statements. In other words, make it be
a compilable test program.
2. Post whatever error message you're getting from the compiler.
3. Post your compiler version. |
