Compiler back issue
David_Delph
Compiler back issue
PostPosted: Mon Jul 23, 2007 10:04 am     Reply with quote
Hi there anyone,
Does anyone have or know how I can get complier version 3.086. Since getting the lastest version some of my old program do not run on things they used to when complied with the new version and unfortunatly I didn't keep a copy of that version Crying or Very sad
Can anyone help?
PostPosted: Mon Jul 23, 2007 10:55 am     Reply with quote
Try using vs. 3.249. You can still download that version, and it's likely
to work with your older programs.
http://www.ccsinfo.com/compilerupdates.php
Also, make sure you use the .H file that comes with that version of
the compiler. Don't keep a local version of the .H file in your project
directory. If you update the compiler, some of the constants may
change their meaning and they won't work properly with the new version.
David_Delph
PostPosted: Mon Jul 23, 2007 2:01 pm     Reply with quote
Thanks,
I do have a version that is in between the oldest version on the website and the one I require, but I will give it a go.
