DS1307
Haytham
DS1307
PostPosted: Mon Jul 23, 2007 5:53 am     Reply with quote
Dear All,
I want to use ds1307 RTC with PIC16F877A microcontroller.
I found the follwoing library:
#define DS1307_SDA  PIN_B1
#define DS1307_SCL  PIN_B0
#use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
// initial DS1307
void init_DS1307()
   output_float(DS1307_SCL);
   output_float(DS1307_SDA);
// write data one byte to
// DS1307
void write_DS1307(byte address, BYTE data)
   short int status;
   i2c_start();
   i2c_write(0xd0);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
   i2c_start();
   status=i2c_write(0xd0);
   while(status==1)
      i2c_start();
// read data one byte from DS1307
BYTE read_DS1307(byte address)
   BYTE data;
   i2c_start();
   i2c_write(0xd0);
   i2c_write(address);
   i2c_start();
   i2c_write(0xd1);
   data=i2c_read(0);
   i2c_stop();
   return(data);
But, I need to use pin RB0 as external interrupt.
I dont know how to modify this library such that it uses another pin instead of B0.
Can any body help me in modifying this library?
Thanl you
Please send me at email if you can:
hshyoukh@yahoo.com
[/code]
treitmey
PostPosted: Mon Jul 23, 2007 8:13 am     Reply with quote
It seems like you would just change
to use the pins of your circuit.
