SPI Newbie connection check
jfk1965
PostPosted: Thu Aug 02, 2007 3:30 am     Reply with quote
Hi All
Attempting my first use of SPI was wondering if someone could check if I have connected things up ok as the pcb has to go off to be made before I get to check things fully out due to time restrictions.
I'm connecting to a Microchip MCP41100 digital potentiometer to a 16F690.
My connections are :-
Pin 9 of the PIC(SDO) to pin 3(SI) of the digipot
Pin 13of the PIC(SDI) to pin 1(CS) of the digipot
Pin 11 of the PIC(SCK) to pin 2(SCK) of the digipot
TIA
JFK
PostPosted: Thu Aug 02, 2007 3:54 am     Reply with quote
Have you checked out page 7 of the Digital Potentiometer Design Guide?
Here several possible configurations are described for the SPI setup. None of these has SDI of the PIC connected to the CS of the digipot...
jfk1965
PostPosted: Thu Aug 02, 2007 5:16 am     Reply with quote
Thats correct it doesn't but the digipot data sheet doesn't have a pin labelled SDO and the only other available is labelled CS and it's function is described as the SPI port chip select pin and is used to execute
a new command after it has been loaded into the
shift register.
JFK
PostPosted: Thu Aug 02, 2007 6:22 am     Reply with quote
The 8 pin digipot doesn't have an SPI output pin, the 14 pin version does (named SO).
Connecting the PIC's SDI pin to the digipot's CS is not going to work while SDI and CS have completely different functions (both are inputs !).
CS is short for Chip Select and is used on the SPI bus to make it possible for multiple chips to select the same data and clock lines. Just before you are going to send data to any chip on the bus you activate the CS line for that particular chip. When finished communicating you disable the CS line again.
The SDI pin is used for reading data in from the external device. You already figured out that the digitpot doesn't have a corresponding SDO so this means SDI on the PIC is not going to be used.
Note: Never create a design with open input ports as oscillation might cause high current consumption. Connect the SDI input to Vcc or Vdd (with pull-up or pull-down resistor).
Because SDI on the PIC is not going to be used as a SPI input you might have considered to configure this pin as a digital output. This isn't going to work as the PIC hardware overrules any manual TRIS setting for this pin and makes it an input (see chapter 13.3 of the PIC datasheet).
jfk1965
PostPosted: Thu Aug 02, 2007 7:03 am     Reply with quote
Thanks thats clearer do I assume that the CS isn't a dedicated pin on the pic as there doesn't appear to be one in the pic datasheet and can be assigned to any spare I/O pin (except the SDI pin)?
thanks again ckielstra your time and partience is appreciated.
JFK
PostPosted: Thu Aug 02, 2007 7:29 am     Reply with quote
Yes, you can take almost any pin you want. Make sure to check the section on I/O ports in the datasheet as some ports have limitations, for example RA3 can only be used as input.
jfk1965
PostPosted: Thu Aug 02, 2007 7:36 am     Reply with quote
I'm 100% clear now in what I'm doing.
Thanks again
JFK
PostPosted: Thu Aug 02, 2007 7:37 am     Reply with quote
A design hint: If you are only using SPI for controlling the digipot you might consider implementing the SPI driver in software instead of in hardware (easy to do). This way you don't use the inbuilt SPI hardware and then the SDI pin is free for other uses.
jfk1965
PostPosted: Thu Aug 02, 2007 8:22 am     Reply with quote
Thanks for the suggestion i'll consider it in the future, but for this application I have sufficient pins available.
JFK
