AdamkT1
| communication between 18F452 (Master) & 16F877 (Slave) |
Posted: Sat Jul 21, 2007 12:22 am |
I am having problems in creating a communication link between 18F452 (the Master) & 16F877 (The Slave).
As mentioned before one of my constraints is that I can’t use any interrupt based routine as they are being used by other components.
A brief description of the project is that the master asks the slave to send in the GPS data by putting logic ‘1’on the Pin RTR. The slave after reading the data from GPS sees this flag and goes into the routine of sending the data to the master. Now to ensure that the data received by the master is correct or not, the master sends the data back to the slave, who compares the received data with the data sent. I am trying to use the same pins for data Rx & Tx, so I am changing the pins direction for Rx/Tx.
I have succeeded in developing the data sending mechanism from Slave to Master. The data received is then displayed on the port which always seems to be correct.
The problem is that the data sending back does not work properly.
The debugging has showed that the pins direction gets properly sets but after that the program does not function as it should. The pins do not get the logic levels of 1 & 0 and hence get stuck.
The code segment given below does not function:
| Code: | PORTD=0;
SET_TRIS_D(SysTx); // set the direction for Tx
delay_ms(5);
CHK=Hi;
delay_ms(5);
DTR=Hi;
delay_ms(5);
PORTB=0xFF;
while (Go1==Lo); |
Below is the complete listing, I am desperately needing help...
==========Code for master========================
| Code: | #include <18F452.h>
#define Hi 1
#define Lo 0
#define SysInitz 0x03
#define SysTx 0x1A
#define SysRx 0x27
#bit DTR = PORTD.0 // Data Terminal Ready (in)
#bit CLK = PORTD.1 // Clock (in)
//PIN_D2 is used for Rx/Tx // Data in/out (in/out)
#bit GO1 = PORTD.3 // Data Read (in/out)
#bit RTR = PORTD.4 // signal for 877 to get ready to receive(in/out)
#bit CHK = PORTD.5 // For Checking any error in data received.(In)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
int8 LAT,LON;
void TxByte(int8 data)
int8 ctr;
PORTD=0;
delay_ms(5);
CHK=Hi;
delay_ms(5);
DTR=Hi;
delay_ms(5);
PORTB=0xFF;
while (Go1==Lo);
for(ctr=0; ctr<8; ctr++)
while(CLK==Lo);
output_bit(PIN_D2, shift_left(&data,1,0));
while(CLK==Hi);
}// end for
CHK=Lo;
DTR=Lo;
delay_ms(2);
}//end TxByte
int8 RxByte(void)
int8 ctr,data;
SET_TRIS_D(SysRx); // set the direction is set for Rx
delay_ms(5);
while(CHK==Lo);
while(DTR==Lo);
GO1=Hi; // No data read yet
while (CLK==Hi);
while (CLK==Hi); //wait for low edge of CLK
shift_left(&data,1,input(PIN_D2));
while (CLK==Lo); //wait for high edge of CLK
GO1=Lo; // data has been read.
while (DTR==Hi);
RTR=Lo;
delay_ms(2);
return(data);
}//end getByte
float get_LAT_LON(void)
int8 n,data, Deg, Min,Sec,ErrCtr;
float tmp;
for (n=0; n<3;n++)
do
data= RxByte();
PORTC=data;
TxByte(data);
delay_ms(5);
ErrCtr++;
if (ErrCtr>=9) return(0);
}while (CHK==Hi);
switch (n)
case 0:
Deg=data;
case 1:
Min=data;
case 2:
Sec=data;
}//end switch
}//end for
tmp=Deg+(Min/60) + (Sec/3600);
return(tmp);
void get_GPS_Data(void)
LAT=get_LAT_LON();
LON=get_LAT_LON();
}//end get_GPS_Data
void SysInit(void)
PORTD=0;
SET_TRIS_D(SysInitz); //0x25 set the direction is set for Rx
delay_ms(5);
RTR=Hi;
delay_ms(5);
}//end SysInit
SET_TRIS_A(0);
SET_TRIS_B(0);
SET_TRIS_C(0);
//Direction of PORTD is done in Send/Get byte routines
SET_TRIS_E(0);
PORTA=0;
PORTB=0;
PORTC=0;
PORTD=0;
PORTE=0;
delay_ms(100); //let the system stabilize
while (TRUE)
/*============Dummy Work Here============
Here actual tasking like reading switches,
vector Calculations and giving servo commands
shall be done here. The delay is to mimic the
above mentioned functions. This is to remove
when actual code is developed for all the
above activities.*/
SysInit();
if (DTR==Hi)
get_GPS_Data();
}//end if
RTR=Lo;
delay_ms(5);
PORTE=~PORTE;
}//end while
================Code for Slave=====================
| Code: | #include "16F877.h"
#bit DTR = PORTD.0 // Data Terminal Ready (out)
#bit CLK = PORTD.1 // Clock (out)
#bit Go1 = PORTD.3 // Go (in/out)
#bit CHK = PORTD.5 // For Checking any error in data received.(out)
#define Hi 1
#define Lo 0
#define SysInitz 0x10
#define SysTx 0x18
#define SysRx 0x05
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
int8 LAT_Deg,LAT_Min,LAT_Sec;
int8 LON_Deg,LON_Min,LON_Sec;
int8 RxByte(void)
int8 ctr,data;
delay_ms(5);
PORTB=0xFF;
while(CHK==Lo);
while(DTR==Lo);
CLK=Hi;
CLK=Lo;
delay_ms(2);
CLK=Hi;
delay_ms(2);
while (DTR==Hi);
RTR=Lo;
delay_ms(2);
return(data);
}//end getByte
int8 ctr;
PORTD=0;
delay_ms(5);
CLK=Hi;
CHK=Hi;
DTR=Hi;
while (Go1==Lo);
CLK=Lo;
delay_ms(2); // let the pin stabilize
CLK=Hi;
}// end for
CLK=Lo;
CHK=Lo;
DTR=Lo;
delay_ms(2);
}//end sendByte
void SendByte_Confirm(int8 TxData)
int8 RxData;//,ErrCtr;
CHK=Lo;
TxByte(TxData);
RxData=RxByte();
PORTB=RxData;
PORTC=TxData;
if (TxData!=RxData)
CHK=Hi;
CHK=Lo;
}//end sendByte_Confirm
void SysInit(void)
PORTD=0;
SET_TRIS_D(SysInitz); // direction is set for Tx initially
DTR=Hi;
delay_ms(5);
}//end SysInit
void get_LAT_LON()
//=======Assumed Values, GPS Data Read Code here===========
LAT_Deg=78;
LAT_Min=43;
LAT_Sec=51;
LON_Deg=34;
LON_Min=28;
LON_Sec=12;
SET_TRIS_A(0);
SET_TRIS_B(0);
SET_TRIS_C(0);
SET_TRIS_E(0);
PORTA=0;
PORTB=0;
PORTC=0;
PORTD=0;
PORTE=0;
delay_ms(100); //let the system to stabilize
while (TRUE)
get_LAT_LON();
if (RTR==Hi)
PORTE=~PORTE;
sysInit();
SendByte_Confirm(LAT_Deg);
//! SendByte_Confirm(LAT_Min);
//! SendByte_Confirm(LAT_Sec);
DTR=Lo;
}//end while
} | [/code] |
