I2C & INTERRUPT
hexfet13
I2C & INTERRUPT
PostPosted: Mon Jul 16, 2007 4:55 pm     Reply with quote
Hi at all.
I'm using an i2c rtc and the program stop after the execution of initialization routine because the translation of instruction i2c_start() is the seguent:
.................... i2c_start();
064E: BSF 29.4
064F: MOVF 29,W
0650: BSF 03.5
0651: MOVWF 07
0652: MOVLW 04
0653: MOVWF 77
0654: DECFSZ 77,F
0655: GOTO 654
0656: BCF 03.5
0657: BSF 29.3
0658: MOVF 29,W
0659: BSF 03.5
065A: MOVWF 07
065B: MOVLW 03
065C: MOVWF 77
065D: DECFSZ 77,F
065E: GOTO 65D
065F: BCF 03.5
0660: BCF 07.4
0661: BCF 29.4
0662: MOVF 29,W
0663: BSF 03.5
0664: MOVWF 07
0665: MOVLW 04
0666: MOVWF 77
0667: DECFSZ 77,F
0668: GOTO 667
0669: BCF 03.5
066A: BCF 07.3
066B: BCF 29.3
066C: MOVF 29,W
066D: BSF 03.5
066E: MOVWF 07
066F: BCF 03.5
0670: CLRF 28
0671: BTFSC 0B.7
0672: BSF 28.7
0673: BCF 0B.7
In the last line, bit 7 in register 0B (INTCON) is cleared, so global interrupt id disabled( and never enabled after in the code).
It is correct this kind of translation?
I'm using pch 4.032
PostPosted: Mon Jul 16, 2007 8:17 pm     Reply with quote
Post a really short little test program that shows the problem. Limit the
code to 10 lines. Post all #include, #fuses, and #use statements.
The program should be compilable without errors. (i.e., post all variable
declarations as well).
hexfet13
PostPosted: Tue Jul 17, 2007 3:43 am     Reply with quote
I've compiled my project now, and the compiler output is the seguent:
>>> Warning 216 "C:\Programmi\PICC\Projects\18F452-RS232.c" Line 174(0,1): Interrupts disabled during call to prevent re-entrancy: (@I2C_WRITE_1)
>>> Warning 216 "C:\Programmi\PICC\Projects\18F452-RS232.c" Line 174(0,1): Interrupts disabled during call to prevent re-entrancy: (@I2C_READ_1)
>>> Warning 216 "C:\Programmi\PICC\Projects\18F452-RS232.c" Line 174(0,1): Interrupts disabled during call to prevent re-entrancy: (glcd_WriteCmd2)
>>> Warning 216 "C:\Programmi\PICC\Projects\18F452-RS232.c" Line 174(0,1): Interrupts disabled during call to prevent re-entrancy: (glcd_WriteByte)
Interrupt occur every 10 ms(programmed on tmr0).
Actually i call adc_read()( that read adc value) every 30ms and refresh_clk() every 1s, both from interrupt routine.Could be this the cause of disabled Interrupts?
How i can modify my code to read adc every 30ms and refresh time on lcd every 1s (should i call both out of interrupt routine)?
a piece of code is the seguent
#include <16F877A.h>
#device ADC=10
#define CONTRAST 50
#define DS1337_SDA PIN_C4
#define DS1337_SCL PIN_C3
#use i2c(master, sda=DS1337_SDA, scl=DS1337_SCL)
#include <default_param.h>
#include <inizialize.h>
#include <interface.h>
int con=CONTRAST; //lcd contrast
int i_clk=0;
//**** test
char mis_string[4];
#int_rtcc //
void timer_zero() { // interrupt every 10ms
set_tmr0(); // set correct tmro value
key=get_key(); // reading keys
get_adc(); /* read adc value (the value is stored in a variable measure
defined as int16 in inizialize.h */
if(i_clk++==100){ // every 1000ms
refresh_clk(); // this procedure read time from RTC and update it on lcd
i_clk=0;
if (!(i_clk%33)){
glcd_gotoxy(1,0,0x00);
glcd_putc("Measure:");
sprintf(mis_string,"%4lu",measure);
glcd_putstr(mis_string); // display a strung on lcd
:loop
goto loop;
rnielsen
PostPosted: Tue Jul 17, 2007 8:33 am     Reply with quote
It's not a good idea to call a function from inside an ISR(Interrupt). ISR's should be short and simple. Have one of the timers set a flag every 30ms and another flag at 1s. Then, have each flag serviced from within the main() body. I believe calling these routines, from within the ISR, is causing your problem.
Ronald
