Bill Boucher
Joined: 04 Feb 2005 Posts: 34 Location: Chatham,ON,CA
Posted: Tue Jul 17, 2007 10:18 am |
The chip is a 10 MIPS max microcontroller so the max internal osc is 40 MHz. That said, your external clock source would be multiplied x4 by the PLL. So, if the internal max is 40 MHz, then the external max is 10 MHz.
To directly answer your question, no, you can't use a 20MHz crystal. The range with PLL enabled is 4 to 10 MHz. |
