Hi, I have the ver. 3.222 PCH but I need program the pic16f886. where can I download the new ver. because 3.222 not support that pic
tnks
Posted: Mon Jul 16, 2007 3:09 pm
PCH doesn't support the 16F-series. You need the PCM compiler.
Also, just getting the .H file doesn't add support for the new PIC.
The main support for the new PIC is in the Devices.dat file and
the PCM.DLL file.
If you have the full IDE (PCWH), you can use the Device Editor
to create an entry for the new PIC. See this post for instructions.
http://www.ccsinfo.com/forum/viewtopic.php?t=29362
But even then, you may not have full support for the peripheral
modules in the PIC, if they are sufficiently different than the PIC
that you used as a "base" to make the new Devices.dat entry.
