16F877 & 18F452 communication
AdamkT1
PostPosted: Tue Jul 10, 2007 7:38 am     Reply with quote
I am trying to establish a communication link between 16F877 and 18F452, where in the 877 acting as master for sending byte data to 452 acting as the receiver.
The problem is that I cant use the standard I2c routines due to a number of reasons. One of them being 18F452 already using interrupts for other functionalities and being a beginner / student, I wish to keep the things as much simple as possible. Therefore I had to develop my own algorithm.
I tried my best not to bother this forum as much as possible but could not solve the problem on my own. So this is an SOS situation for me.
The code for 877 (The sender ) is :
#include <DEFS_877.h>
#bit DTR = PORTD.0 // Data Terminal Ready (Out)
#bit CTS = PORTD.1 // signal from 18F452 ready to receive (Input)
#bit CLK = PORTD.2 // Clock (out)
#bit DO1 = PORTD.3 // Data out (out)
#bit DRD = PORTD.4 // Data Read (in)
#define Hi 1
#define Lo 0
#use fast_io(A)
#use fast_io(B)
//!#use fast_io(c) // cant make this execute in CCS  compiler
#use fast_io(D)
void sendByte(int8 data)
   int8 ctr;
   PORTC=data;
   DTR=Hi; // Signal being ready for sending.
   CLK=Hi;
   delay_ms(2);
   while (CTS==0); //Wait for CTS to go high.
   for(ctr=0; ctr<8; ctr++)
      output_bit(DO1, shift_left(&data,1,0));
      CLK=Lo;
      delay_ms(5); // let the pin stabilize
      CLK=Hi;
      delay_ms(5); //let the pin stabilize
   DTR=Lo;
   CLK=Lo;
   delay_ms(5); // delay for EEPROM write cycle
}//end sendByte
   int8 n1;
   SET_TRIS_A(0); // Pin A1,A2 inputs
   SET_TRIS_B(0);
   SET_TRIS_C(0);
   SET_TRIS_D(0x12);
   PORTA=0;
   PORTB=0;
   PORTC=0;
   PORTD=0;
   delay_ms(500); //let the system to stabilize
   while (TRUE)
      for (n1=10; n1<100;n1++)
         sendByte(n1);
         delay_ms(200); //just to be able to see the port values
     }//end for
   }//end while
18F452 Code is:
#include <18F452.h>
#define Hi 1
#define Lo 0
#bit DTR = PORTD.0 // Data Terminal Ready (in)
#bit CTS = PORTD.1 // signal from 18F452 ready to receive (out)
#bit CLK = PORTD.2 // Clock (in)
#bit DI1 = PORTD.3 // Data out (in)
#bit DRD = PORTD.4 // Data Read (out)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
int8 getByte(void)
   int8 ctr,data;
   CTS=Hi;
   while (DTR==Lo);
   while (CLK==Lo);
      while (CLK==Hi); //wait for low edge of CLK
      shift_left(&data,1,input(DI1));
      while (CLK==Lo); //wait for high edge of CLK
   CTS=Lo;
   return(data);
}//end getByte
   int8 data;
   SET_TRIS_B(0);
   SET_TRIS_C(0);
   SET_TRIS_D(0x0D);
   PORTA=0;
   PORTB=0;
   PORTC=0;
   PORTD=0;
   while (TRUE)
      data= getByte();
      PORTC=data;
      delay_ms(200);
   }//end while
After hours of debugging, what I have learnt so far is that the statement :
in the for loop of sendByte is not working.
Hardware connection details:
I have just connected the Port D pins of 877 to PortD pins of 452 with out any pullups/pulldowns.
PostPosted: Tue Jul 10, 2007 8:02 am     Reply with quote
The problem is your pin definition.
The 'output_bit' command, requires a pin definition, in the format 'PIN_D3', while your define, had D01, defined as 'PORTD.3'...
AdamkT1
PostPosted: Wed Jul 11, 2007 10:13 am     Reply with quote
Thank you.
It solved my problem.
