Fast 16f877
jjude
Fast 16f877
PostPosted: Mon Jul 09, 2007 10:47 am     Reply with quote
What microcontroller is fast 16f877 but software conpatible?
Sorry my bad english.
PostPosted: Mon Jul 09, 2007 11:44 am     Reply with quote
There aren't any 40 MHz machine-language compatible parts.
To see this for yourself, do this:
Go to the Microchip parametric search page for the PIC16 chips:
http://www.microchip.com/ParamChartSearch/params.aspx?branchID=1002&mid=10&lang=en&pageId=74
Find this line:
Max. Speed MHz
Select "40" (for 40 MHz).
The click the "Search" button and after that, click the "Detail" button.
It will give you a list of PIC16 chips that can run at 40 MHz.
Look at the details of the chips. They're not compatible with the 16F877.
Your only good choice is to go to the PIC18F series. That requires the
PCH compiler (not the PCM compiler).
Pret
PostPosted: Tue Jul 10, 2007 3:21 am     Reply with quote
Depends on your project. 18F458 is pin to pin compatible, with small exceptions. And if your code was written in CCS it will work with very few modifications.
