Reading and writing data structures to flash
Billy
PostPosted: Fri Jul 06, 2007 9:52 am     Reply with quote
I neet to be able to store some large data structures in Flash on a PIC 18F4680 so they are preserved when the power is off.
There are a few things I don't understand about this - I assume I use the write_program_memory() function - but how do I know where my code ends and where the empty memory begins.
The structs contain several arrays of SInt16's plus int8's and pointers of both types. Ideally I want an easy way to copy an entire structure to flash, and to read and write individual variables within the structure.
I'm assuming that working directly with the structures in flash will be slow so my code will start by copying all the flash data into RAM.
I'm also unsure of the best (i.e most efficient) way to convert the SInt16's to and from the int8 values that will be stored in flash - can I just use the make8() and make16() functions even though the documentation only refers to their use with unsigned values?
Although I'm reasonably profecient at C I'm not the best programmer so some simple and clear advice would be greatly appreciated.
PostPosted: Fri Jul 06, 2007 12:37 pm     Reply with quote
You need to tell the compiler to reserve a range of Flash memory
addresses for your use. Then the compiler won't use them for code.
You can do this by using the #org statement. See the Ex_logger.c file
for an example:
c:\program files\picc\examples\Ex_Logger.c
Near the start of that file, there's a large number of #org statements
buried within #if and #elif statements. You don't have to worry about
that. That's only for the 16F-series PICs, which have ROM pages.
You're using an 18F, so this code is all you need to define the buffer:
#define BUFFER_SIZE   4096  // in bytes
#define PROGRAM_MEMORY_SIZE   getenv("PROGRAM_MEMORY")
#define BUFFER_END      PROGRAM_MEMORY_SIZE-1
#define BUFFER_START   (PROGRAM_MEMORY_SIZE-BUFFER_SIZE)
#org BUFFER_START, BUFFER_END {}
