jmac_link
Disabled timer1 interrupt function affects I2C |
Posted: Thu Jun 28, 2007 10:39 am |
Hi All,
I have some working code on a PIC18F4525 that receives Intel hex records via the I2C and reprograms the PIC flash memory. After adding a Timer 1 interrupt function (unrelated to the I2C), I noticed the I2C started occasionally missing characters. I tried disabling the timer interrupt but characters were still missed. I finally tracked it down to local variables in the (disabled!) timer interrupt routine; if I make them global the I2C runs Ok!
Here's the code (you could chop out all but the variable declarations and still see the problem):
/* Timer 1 Handler - used to debounce synth lock */
// INT8 lockCount = LOCK_DEBOUNCE_COUNT; // Works if these declarations are used
// INT8 lockShadow;
#INT_TIMER1
void timer1_handler() {
static INT8 lockCount = LOCK_DEBOUNCE_COUNT; // Problems when using local varables!
INT8 lockShadow;
set_timer1(T1_POLL_TIME);
lockShadow = LOCK;
if( lockDebounced == lockShadow )
if( lockCount )
lockCount--;
lockDebounced = lockShadow;
I checked the timer interrupt enable flag is clear in the I2C routine and a breakpoint put in the timer handler never triggers.
Comparing .lst output files the only difference is when variables are local to the interrupt there are MOVLB 1 and MOVLB 0 instructions, but as the timer interrupt is never called, why would this affect the I2C interrupt?
Could this be a PIC gotcha, something to do with the way global/local variables are handled in the PIC?
Any help greatly appreciated!
Regards,
John Mackenzie
PS Complier version is 3.245. Using MPLAB ICD 2 to debug. |
Posted: Thu Jun 28, 2007 10:52 am |
Sounds like a memory corruption problem. Most likely somewhere in your code you are writing out of the array bounds and overwriting another variable. Often these kind of errors pop up directly when testing code the first time but sometimes they are masked because you are overwriting a variable that is not used at that time. Changing the code has shuffled the variables around and now the old bug becomes visible.
My first suspect would be the I2C ISR routine as the local variables of all interrupt routines are sharing the same memory region. |
jmac_link
Posted: Fri Jun 29, 2007 10:34 am |
Thanks for your suggestion ckielstra.
I checked all variable use, pointer sizes, memory allocation etc. All looks Ok and its still not working!
What I have found looking at the .sym file is the timer1_handler() variable lockShadow shares a memory location with a variable in the i2c interrupt:
1AE write2ProgramMemory.@SCRATCH
1AF i2c_interrupt.dummy <= shared location
1AF timer1_handler.lockShadow <=shared location
1B0 i2c_interrupt.inData
1B1 complete_i2c_incoming.dummy
This looks like it could be causing the problem but I cant see why - the i2c interrupt is only called once at the start of the program ( it receives a command byte to enter reprogram mode ) after which the i2c interrupt is disabled and the SSPIF flag is polled to read in bytes from the i2c. Also timer1 is disabled so timer1 and i2c the interrupts should never occur at the same time.
Will ponder this over the weekend... |
