I'm trying to run a PIC 18F2480 at 32 MHz (8MHz * 4x Multiplier) with a baud rate of 10400. When I try this, I receive only garbage. Is there a certain limitation in the baud rate values I can use when running the PIC at a high frequency?
When I run the PIC at 16 MHz (4MHz * 4X Multiplier), the 10400 baud rate works just fine.
Thanks for the help.
Posted: Tue Jun 26, 2007 1:23 pm
The data sheet says the internal oscillator isn't very accurate.
Also, the PLL has a lot of jitter.
Look in Tables 27-7 and 27-8.
Internal oscillator accuracy is +/- 2% at 25 deg. C.
It's +/- 5% over a wider temperature range.
The PLL has +/- 2% jitter.
Do a test. Use the H4 fuse with an 8 MHz crystal (instead of the
internal oscillator). See if your problems go away.
