USART receive problem
NeilOne
PostPosted: Sat Jun 23, 2007 5:07 am     Reply with quote
I use 18f4520, wanna use USART to communicate data with PC. MCU could transmit data to PC, but couldn't receive data from PC. The source code is as follows. Anyone kowns the reason?? Thank u for your answering:)
#include <p18f4520.h>
#include <sw_i2c.h>
#include <delays.h>
#include <usart.h>
#pragma config OSC = HS
#pragma config PWRT = OFF
#pragma config BOREN = OFF
#pragma config WDT = OFF
#pragma config MCLRE = ON
#pragma config PBADEN = OFF
#pragma config LVP = OFF
void init(void)
CMCON=0b00000111; // Close Comparator
TRISA=0b00010000; // Configure PORTA I/O
TRISB=0b00000001; // Configure PORTB I/O
TRISC=0b00000000; // Configure PORTC I/O
TRISD=0b00000000; // Configure PORTD I/O
TRISE=0b00001000; // Configure PORTE I/O
ADCON1=0b00001111; // Enable digital I/O
SPBRG=64; // Transmission choices for the Baud Rate 4800bps(SPBRG=(20000000/ 4800/64)-1)
BAUDCONbits.BRG16=0; // Choice 8-bit baud rate generator
TXSTAbits.BRGH=0; // High Baud Rate
TXSTAbits.SYNC=0; // Asynchronous mode
RCSTAbits.SPEN=1; // Enable Serial Transmit
TXSTAbits.TX9=0; // 8-bit Transmission
TXSTAbits.TXEN=1; // Enable Transmission
void main( void )
char i = 'Q';
char wr[]={"world"};
char ra[7];
init();
WriteUSART(i); // Display a ‘Q’ to the USART
putsUSART(wr); // Display a word to the USART
while (!DataRdyUSART());//!PIR1bits.RCIF);//
i = ReadUSART();//getcUSART();
// TransmitData();
//getsUSART(display_1line, 10);
WriteUSART(i);
//while(!PIR1bits.TXIF)
//continue;
PostPosted: Sat Jun 23, 2007 9:15 am     Reply with quote
Your code looks like C18 code. This is the CCS compiler forum.
You should ask your questions in the Microchip C18 forum:
http://forum.microchip.com/tt.aspx?forumid=3
NeilOne
Thank you
PostPosted: Sat Jun 23, 2007 10:13 am     Reply with quote
Thank uSmile
