example program EX_SQW works with one pin, but not another
SparkyEE
PostPosted: Thu Jun 21, 2007 8:50 am     Reply with quote
The EX_SQW.c example code included with the CCS compiler works just fine on my PICkit2 debug express demo board (16F887), if I leave the pin at PIN_B0, It does NOT work when simply changing the output pin to PIN_A5.
I have also tried including the line: #use standard_io, it makes no difference.
I'm lost as to why this simple change breaks the program.. Any thoughts?
Thanks.
    printf("Press any key to begin\n\r");
    getc();
    printf("1 khz signal activated\n\r");
    while (TRUE) {
    output_high(PIN_B0);
    delay_us(500);
    output_low(PIN_B0);
    delay_us(500);
treitmey
PostPosted: Thu Jun 21, 2007 11:54 am     Reply with quote
I got a nice square wave with the PICDEM 2 plus and rev3.249
NOTE THAT THIS IS 16F877 NOT 16F887.. but software seems OK
#include <16F877.h>
#device *=16
#use delay(clock=10000000)
#fuses hs,nowdt,nolvp,protect,put,nobrownout
#use rs232(baud=19200,xmit=PIN_E0,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
  setup_adc_ports(NO_ANALOGS);
  fprintf(DEBUG,"Press any key to begin\n\r");
  fprintf(DEBUG,"1 khz signal activated\n\r");
  while (TRUE) {
    output_high(PIN_A5);
    delay_us(500);
    output_low(PIN_A5);
    delay_us(500);
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Jun 21, 2007 6:24 pm     Reply with quote
I had a similar problem recently. See this thread http://www.ccsinfo.com/forum/viewtopic.php?t=31075. The discussion began with an interrupt problem, but them PCM suggested interrupt itself was not the source of the problem.
Read the label, before opening a can of worms.
PostPosted: Thu Jun 21, 2007 8:29 pm     Reply with quote
1. Post your compiler version. You can find it at the start of the .LST
file for your project. The .LST file is in your project directory.
The compiler version is a 4-digit number such as 3.249, 4.041, etc.
2. Confirm the PIC that you're using. Is it 16F877 or 16F887 ?
