RF Interrupt Advice
TheRidDler
RF Interrupt Advice
PostPosted: Tue Jun 19, 2007 1:28 pm     Reply with quote
Hi all! I received a copy of one of my friends' code to control RF operations between a 18F252 PIC and a PC. The code is faulty however. Could you please help me in getting the bugs out, as i am totally new to programming pics and trying to understand this. One problem that i can see is that the timer 3 interrupt is being enabled, but is called nowhere. Any advice?
#define RF_TXD PIN_A0
#define RF_RXD PIN_A1
void RX_Sel(int s)
   switch( s )
         case 0:
            output_low(PIN_C0);
         case 1:
         output_high(PIN_C0);
void TX_Sel(int s)
   switch( s )
         case 0:
         output_low(PIN_C1);
         case 1:
         output_high(PIN_C1);
void Receive()
      int  counter = 0x00, position = 0x00;
      char Header[3] = {0x00,0x00,0x00};
      char Identifier = 0x00;
      char Received[];
      int  RFtimeout = 20;
      for (counter=0;counter<128;counter++)
          Received[counter] = 0x00;                                                      // Clears the received string so that
        // new data can be read
      counter = 0x00;
      #use rs232(baud=9600,parity=N,xmit=RF_TXD,rcv=RF_RXD,bits=8,RESTART_WDT,errors)    // data from PC to PIC
      RX_Sel(0);        //Enable Receiver, activated on low..
      //WAITING RX ROUTINE..
      set_timer3(0x0000);                                                 //Set up Timer 3
      timeout = 0;
      enable_interrupts(int_TIMER3);                                           //Switched on Timer 3 interrupt
      enable_interrupts(global);                                                         //Switches on all interrupts
      WAIT:
         Header[0] = getchar();                                                             //Wait till char 1 of received string
        //found on RX pin
         IF (timeout > RFtimeout)
         {        //String is discarded if not found within
            disable_interrupts(int_TIMER3);                                                //specified timeout
            timeout = 0;
            RFIndicator = 0x01;                                                 //This is the timeout and well received
            goto OUT;                                                      //indicator
         IF (Header[0] != 0xCC)                                                 //First checksum char must be 0xCC
            goto WAIT;
         Header[1] = getchar();                                                //Next char to be received
            timeout = 0;
            RFIndicator = 0x01;                                                 //Timeout and well received indicator
            goto OUT;
         IF(Header[1] != 0x33)                                                 //Second checksum char must be 0x33
            goto WAIT;
         Header[2] = getchar();
            timeout = 0;
            RFIndicator = 0x02;                                                   //Timeout and well received indicator
            goto OUT;
         IF(Header[2]!= 0x55)                                                //Third checksum char must be 0x55
            goto WAIT;
         Identifier = getchar();                                                            //Identifier byte (Address of the
        //listeting module)
            timeout = 0;
            RFIndicator = 0x03;                                                 //Timeout and well received indicator
            goto OUT;
         IF (Identifier != Address)                                             //If Address mismatch WAIT
            goto WAIT;
         Identifier = 0x00;
         While (counter < 128)                                                //Checksum Complete.
         {                                                               //Now data is read in.
          Received[counter] = getchar();
          counter++;
         RX_Sel(1);                                                              //Receiver switched OFF
         counter = 0x00;
         while (counter < 64)                                                //Decode Data
           DecodedData[position] = decodeRF(Received[counter],Received[counter+1]);        //decodeRF function return byte for byte
           position++;
           counter = counter + 2;
         RFIndicator = 0x00;                                                 //Timeout and well received indicator
      OUT:                                                             //Out Routine
         disable_interrupts(global);                                           //Disables all interrupts
void Transmit(char IDUnit)
       int8 i = 0;
       set_tris_c(0x80);
       delay_ms(40);        //Give Relay Unit time to change TRX to RX
       TX_Sel(0);                                                              //Transmitter ON
       delay_ms(5);
       for (i=0;i<200;i++)                                                      //Training sequence
         putc(0xAA);                                                      //Sends 0xAA chars to confirm Txmit
       putc(0xFF);
       putc(0xFF);
       putc(0xCC);                                                            //Header #1
       putc(0x33);                                                              //Header #2
       putc(0x55);                                                              //Header #3
       putc(IDUnit);                                                            //ID of unit to be communicated to
       for (i=0; i<128; i++)                                                    //Data
         putc(EncodedData[i]);
       putc(0x00);                                                              //Ending Sequence of transmition
       putc(0x00);
       TX_Sel(1);                                                              //Transmitter OFF
       for (i=0;i<64;i++)
      {        //clear the TX buffer for next transmission
          ToBeSend[i] = 0x00;
PostPosted: Tue Jun 19, 2007 4:34 pm     Reply with quote
My advice is to find some radio units that are compatible to the Nordic
brand units. Then do a web search for CCS code. The Nordic brand
doesn't seem to have much sample code available.
TheRidDler
A more crucial problem...
PostPosted: Tue Jun 19, 2007 4:48 pm     Reply with quote
Thnx PCM, ill look into that now... i have however ran into another problem much greater along the way.
Here is my setup: Im using a remote board with Radiometrix RF transmitter and receiver. The datasheets for them can be found here :
http://www.radiometrix.co.uk/dsheets/tx2arx2a.pdf
At the PC side i have a nRF905 tranceiver unit:
http://www.mpfreezone.com/downloads/files/RS232-RFmanual1.22.pdf
On my remote board i receive GPS data. I would like to Manchester encode the data and send it to the tranceiver at PC side. This does not pose to be such a big problem,
HOWEVER
The tranceiver unit at PC side has built-in CRC, Address and Preamble capabilities. All said and done i encode my data at remote side, include a
chosen crc, address and preamble and send it away, but dont know the crc, address or preamble of the tranceiver unit! I am correct in saying that
if these 3 don't match, nothing much is going to happen!
ANY advice as to how to get these values from the tranceiver unit?
This is my first RF project and im really still learning, but the problem seems simple enough.
Thank you all for helping a stranger!! Laughing Laughing
