two pic commnicate with PC via RS232?
stefsun
PostPosted: Sun Jun 17, 2007 7:25 pm     Reply with quote
when I use two pic commnicate with PC via RS232,one is 16F877,the other is 18F4523.when I
connect the Oscillator with the pics,they work as following
16F877 18F4523 results
4M 10M NO
4M 4M NO
share the same 4M Oscillator,they work well.
Can I use the Oscillator separately?
arunb
re:
PostPosted: Sun Jun 17, 2007 7:29 pm     Reply with quote
You mean the PICs are sharing an oscillator ??
Dont' know if that is a good idea, but yes you can run the PICs using different oscillators, but keep in mind the max osc. requirements for the PICs,
For serial connection to work, the baud rates of both the PICs must be the same ...
thanks
arunb
PostPosted: Sun Jun 17, 2007 8:14 pm     Reply with quote
Post your #use rs232() statement for each PIC.
Also post the #use delay() and #fuses statements for each PIC.
stefsun
PostPosted: Sun Jun 17, 2007 8:59 pm     Reply with quote
The 16F877 and the 18F4523's PIN25(TX) and PIN26(RX) connect each other.they reply according to PC'instruction separately.
the 16F877 code is
#include <16F877.h>                             // PICF4523 header file
#device ADC=10                                   // 12 bits ADC
#use delay(clock=4000000)                        // for 10Mhz crystal
#fuses XT, NOWDT, NOPROTECT, NOLVP               // for debug mode
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, PARITY=N,BITS =8,stream=MYPC)
         int8 c=0;
         SET_TRIS_C( 0xFF );
               while(!kbhit())
                  delay_us(10);
               if(kbhit())
                           c=fgetc(MYPC);
                              if(2==c)
                                    //putc(c);
                                    printf("877 is ready\n");
                                    SET_TRIS_C( 0x8F );                                       }
                                    SET_TRIS_C(0XFF);                                 }
the 18F4523 code is
#include <18F4523.h>                             // PICF4523 header file
#device ADC=12                                   // 12 bits ADC
#use delay(clock=4000000)                        // for 4Mhz crystal
         int8 c=0;
         SET_TRIS_C( 0xFF );
               while(!kbhit())
                  delay_us(10);
               if(kbhit())
                           c=fgetc(MYPC);
                              if(1==c)
                                    //putc(c);
                                    printf("4523 is ready\n");
                                    SET_TRIS_C( 0xFF );                                       }
