CCP1 Compilation Error
PostPosted: Sat Apr 11, 2009 5:36 am     Reply with quote
Does compiler V4.013 have a bug in the CCP department?
This line
setup_ccp1(CCP_COMPARE_CLR_ON_MATCH);
give me this error message
Error 102 Expect comma
All other variations tried give the same error message.
PostPosted: Wed Apr 15, 2009 5:00 am     Reply with quote
It could easily have. Look at the sticky thread at the head of the forum, about V4, and then think where 4.013 lies in the 'scheme of things'....
However, also look carefully at the lines in front of this one. CCS has a habit of reporting errors in a line, where the 'real' error is several lines earlier, and the line with the report, is the first one, where the compiler can no longer make sense, following the earlier error. I'd say this was actually the most likely reason for your problem.
