RFID
I2C Help |
Posted: Thu Jun 14, 2007 4:40 pm |
Hey Guys,
I'm using a PIC18F2420. I would like a very simple slave code that returns a "1" when the master asks for data. I've been trying the code that came with the compiler but it's not working. Please help ! |
RFID
Posted: Sun Jun 17, 2007 4:06 pm |
Thank you. This helped a little bit. However, I still can't communicate with my master (an external device not a PIC). I was able to communicate with another pre-programmed chip from Microchip. So the problem is in my code.
Here is the slave code I'm using:
#include "C:\Documents and Settings\almatrouk-07\Desktop\Test 2\Test2.h"
BYTE address, buffer[0x10];
#int_SSP
void SSP_isr()
BYTE incoming, state;
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
if(input_state(PIN_B0)==1)
output_low(PIN_B0);
output_high(PIN_B0);
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
if(input_state(PIN_B1)==1)
output_low(PIN_B1);
output_high(PIN_B1);
i2c_write('E');
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_SSP);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
while (TRUE) {
delay_ms(400);
output_high(PIN_B3);
if(input_state(PIN_B2)==1)
output_low(PIN_B2);
output_high(PIN_B2);}
header file code:
#include <18F2420.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#use delay(clock=32768)
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,address=0xA0)
Questions:
1-The second byte of the I2C protocol is the register's address. Do I have to specify it or write 'E' in it? My master only reads info.
2- Can you tell me what I'm doing wrong, the program freezes as soon as it gets to the i2c_write command in the ISR?
Thank you in advance |
Posted: Sun Jun 17, 2007 4:57 pm |
Quote: |
#FUSES LVP//Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=32768) |
There are two immediate problems.
1. The "LVP" fuse setting can cause your PIC to lockup if the PGM pin
goes to a high level. The PIC will then enter programming mode.
Change that fuse to NOLVP. Do this in every program.
2. You're using an extremely slow clock for the i2c slave.
Look in the Electrical Characteristics section of the 18F2420 data
sheet. Look at parameter 100 in this table:
Quote: |
TABLE 26-19: I2C BUS DATA REQUIREMENTS (SLAVE MODE)
100 kHz mode
PIC18FXXXX must operate at a minimum of 1.5 MHz
You didn't say what the i2c clock speed of your master is, but
there's no way that a PIC i2c slave running at 32 KHz is going to work. |
RFID
Posted: Sun Jun 17, 2007 9:20 pm |
I'm using a LEGO Mindstorms NXT Brick to make a sensor for a LEGO Mindstorms NXT. The baud rate of the LEGO Mindstorms I2C is 9600 bits/s. If you need more information please use the link below.
http://mindstorms.lego.com/Overview/nxtreme.aspx
Go to Hardware Developer Kit (HDK) and download the zip file. Then, open the LEGO Mindstorms Hardware Developer Kit PDF File and look at page 9 where they discuss the I2C protocol.
I did what you asked me to do. However, the program still does not work. Here is the code. I hope you can find the error and let me know. Your help is highly appreciated.
C code
#include "C:\Documents and Settings\almatrouk-07\Desktop\Test 3\Test3.h"
#int_SSP
void SSP_isr()
{ if(input_state(PIN_B0)==1)
output_low(PIN_B0);
address = incoming;
// if(input_state(PIN_B1)==1)
// output_low(PIN_B1);
// else
// buffer[address]=65;
// i2c_write(buffer[address]);
i2c_write('E');
// clear_interrupt(int_SSP);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ);
while (TRUE) {
delay_ms(400);
output_low(PIN_B2);
H file
#device adc=8
#FUSES INTRC //Internal RC Osc
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use delay(clock=8000000)
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,force_hw,address=0xA0)
Note: I was using an internal oscillator to do so. |
Posted: Mon Jun 18, 2007 3:10 am |
Obvious comment.
You do have the pull-up resistors on the I2C lines?.
RFID
Posted: Mon Jun 18, 2007 11:32 am |
Yes I did. I have tested my circuit with a pre-programmed PIC from microchip and it works. Therefore, the problem is in the software for sure. However, I'm not using an external oscillator. I don't know if that might cause some problems. |
mskala
Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
Posted: Mon Jun 18, 2007 1:00 pm |
Another dumb question. Are you sure that address 0xA0 is the same one that the pre-programmed chip is using or that the master expects? |
RFID
Posted: Mon Jun 18, 2007 1:11 pm |
The pre-programmed chip has an address of A2. However, I have changed the master's program to call the 0XA0 address. |
Posted: Mon Jun 18, 2007 1:12 pm |
Tell us the exact sequence of i2c bytes that are coming from the
Lego cube module. The Lego manual shows many commands.
Which specific one are you testing now ? Post the sequence of
start bit, slave address byte, data bytes, stop bit, re-start bit (if any).
The CCS slave code can't handle everything. That's why we need
to know the specifics of the i2c command that you're testing. |
RFID
Posted: Mon Jun 18, 2007 1:52 pm |
We looked at this with the logic analyzer and can see that the Master [NXT] I2C Read stops dead after the first two bytes are sent to the slave (PIC).
1st byte: 0xA1 (Read)
2nd byte: 0x02 ("Register Address")
SCL stays low (held by PIC?)
It's as if the PIC doesn't have anything to send back and holds SCL low.
On the PIC we tried to set an LED high to show code entering the "if (state == 0x80)" case, but LED stayed low!
It's as if when the Read interrupt happens, state <> 0x80 as we expect, and we have not allowed for state > 0x80...
Cheers! |
Posted: Mon Jun 18, 2007 2:06 pm |
Disconnect the Lego module from your Slave PIC. Get another PIC
board and program it with the following Master code. Then connect
the Master PIC to the Slave PIC. Run it and see if the master can
talk to the slave. This test will prove if your slave board is working.
Link to Master test code:
http://www.ccsinfo.com/forum/viewtopic.php?t=28097&start=9
Make sure you connect:
- Master SDA to slave SDA
- Master SCL to slave SCL
- Master board's ground to Slave board's ground
- A 4.7K pullup to +5v on each of SDA and SCL (2 resistors total). |
Posted: Mon Jun 18, 2007 3:21 pm |
Minor beware on the latter, if you then move back to the Lego unit.
The Lego stuff, uses a really slow I2C rate, with 4.7K series resistors. Hence the pull-ups, have to be large (they recommend 82K!).
The clock rate shouldn't cause a problem (provided the chip is working - simple LED flash type test called for...), since I2C, is a 'synchronous' bus, with the rate dependant on the master device.
RFID
Posted: Mon Jun 18, 2007 5:35 pm |
Thank you guys, I will work on your suggestions and keep you updated. |
RFID
Posted: Mon Jun 18, 2007 8:38 pm |
PCM programmer. I think you are right. Your program did not work either which makes me think there is a hardware error. Have you used an external oscillator for your slave? If so what was the frequency... My frequencies are 20MHz for the Master (external oscillator) and 8MHz for the slave. I'm using the PICdem 2 Plus for the master and 28-pin board for the slave here are the data sheets.
http://ww1.microchip.com/downloads/en/DeviceDoc/PICDEM%202Plus%20Old%20Version%2051275b.pdf
http://ww1.microchip.com/downloads/en/DeviceDoc/41301A.pdf
I connected the SCL and SDA and checked them more than once. The picdem 2 plus has two built in pull-up resistors so that was given and you can check the data sheet if you want to. I powered the slave from the Master's board and had a common ground between the two boards. I think that the oscillators are the main problems. What do you think ? |
