orlandoG
Receive Data Packets |
Posted: Fri Jun 15, 2007 9:52 am |
Hello!
Does anyone know how to receive a data packet using a serial interrupt?
I got the serial interrupt working fine I just can't figure out how to compare the data received to a command I have predefined. I have posted the source code below.
Thanks in advance!
#include <16F873.h>
#use delay(clock=20000000)
/******************** Local Variable Declarations *****************************/
#define RX_BUFFER_SIZE 32
char rx_buffer[RX_BUFFER_SIZE];
int i=0;
int j=0;
BYTE data;
char command[10];
/******************** Function Delcarations ************************************/
void Initialize(void);
/******************** Initialize Ports *****************************************/
enable_interrupts(INT_RDA);
/******************** Serial Receive Interrupt *********************************/
#int_rda
void Serial_Receive()
rx_buffer[i]=getc();
i=((i+1) & (RX_BUFFER_SIZE-1));
if (i==j) {j = ((j+1) & (RX_BUFFER_SIZE-1));}
/******************** Build String *********************************************/
#define DataAvilable (i!=j)
int GetCharacter(void)
int chr=0;
if (havedata)
chr=rx_buffer[j];
return chr;
/******************** Main Loop ************************************************/
Initialize();
while (TRUE)
if (DataAvilable)
data=GetCharacter();
sprintf(command,"%c",data);
if(*command="READY\r")
printf("Channel 1 On");
if(*command="NOT READY\r")
printf("Channel 1 Off");
Ttelmah Guest
Posted: Fri Jun 15, 2007 2:39 pm |
First of all, I'd change the command!.
The 'reason', is that if this was being sent over a link, with any chance of loss of data, then it is potentially 'dangerous' (depending on what the command is doing...), to have one command 'containing' the other. If the system missed the word 'not', then it could potentially see the 'ready', when it shouldn't.
Now you show no handling for a 'end of command' character. Something like a line feed or similar character, to sow the system, that a command has finished, and it should now interpret this.
So, if you switch (say), to having:
READY<CR>
NODAT<CR>
Then your reader code, can look for the carriage return, and then _terminate the string_ (add a '\0' character at this point in the comparison buffer), then look for the keywords.
The only other problem, is that you can't use '=='. The C '=' command, compares a numeric value, not a string of characters. Lok instead at 'STRCMP', which is the command to compare to strings.
orlandoG
Posted: Fri Jun 15, 2007 3:06 pm |
I do plan on using different commands this was just to use as an example.
Can you provide an example or modify the code as to how to look for a terminating character? I'm not too sure as to where or how to do this
Thanks |
Ttelmah Guest
Posted: Sat Jun 16, 2007 3:20 am |
If you look in 'input.h', at the source code for 'get_string', you will see how to code a function to build a string, and return when the string is complete (with a length limit for safety as well).
This contains some 'extras' (backspace handling primarily), which you won't need.
The alternative (which is quicker when the command completes), is to instead do a 'tree' comparison, on a per character basis.
If you have an array of commands, listed in alphabetical order, and two 'static' counters, one for 'line', and one for 'column', initialised to zero, then when a character arrives, you search 'down' the lines, till you get a match with the first character, incrementing 'line' as you go. Since this is a single character test, it can be done using '==' (quickly) You then increment the 'column' counter, and test the character it is pointing at. If this is '0', then the whole string has been matched, and the 'line' counter gives the command number. If not, you exit, and wait for the next character.
const int8 keywords[8][11] = {
"ACKOFF",
"ACKON",
"AUTOn ",
"Axxxxxxxxx",
"BAUDn ",
"Bxxxxxxxxx",
"CAL_ONn ",
"xxxxxxxxxx"
//Typical array of keywords. 'xxxx' markers added see code for why.
int16 ipno; //temporary used to hold an input 'number'
int8 MyIsdigit(int8 val){
if (val>'/' && val<return>15)
phase=0;
//Now scan the incoming character
while (true) {
if (phase==0) {
//Here I am searching for an element in the text array
temp=(cval>='a' && cval<='z')?cval-32:cval;
//Now I have uppercase only.
while (true) {
srch=keywords[row][col];
if (srch=='\0') {
//Have got to the end of the string
have_command(row);
//call the handler, with the row number of the 'match'
ccnt=0;
else if (srch==tempch) {
//Here the character matches
col++;
else if (srch=='n') {
//Demo of a special command character to read a number
//from the input
col++;
phase=1;
ipno=0;
else if (srch=='x') {
//Here match has failed
phase=0;
//try next row and loop
row++;
//exit the 'while'
if (phase==1) {
//Here I am looking for a numeric field - as each digit arrives, ipval
//is multiplied by 10, and the new character added. If I reach a 'non
//numeric' character, it marks the end of the conversion.
if (Myisdigit(cval)) {
ipno*=10;
ipno+=(cval-'0');
phase=2;
//Loop again, in case the new character is the start of another
//command
If you call this, with each character as it is receiver, it'll call 'have_command', with the row number that matches when a command is seen.
The 'x' lines are added to slightly speed the search.
I wouldn't guarantee this to work, it is cut out of a much larger parser, with checksum handling etc., and I'd not warrant I have got it completely right, but it should be 'close'.
You call 'parse(val)', with each received character.
