softjad
| sht11 with rs232 communication problem! Please Help! |
Posted: Wed Jun 13, 2007 5:45 am |
Hello.
Driver for SHT: http://www.ccsinfo.com/forum/viewtopic.php?t=28564
I tried this driver with sht11, and I had a problem:
In my project, I have an interruption int_rda (reception of data rs232), but when I execute the function sht_rd (restemp, truehumid);, the interruption stops working.
I get to send data by int_tbe (transmitting of data rs232), but I don't get to receive data after the first reading of the sensor.
Somebody know because it is that the interruption stops working?
Thanks |
Posted: Wed Jun 13, 2007 7:12 am |
My guess would be, that you have something called in both the INT_RDA function, and in the rest of the code, which results in the interrupt being disabled in the sht_rd function. then when the interrupt is re-enabled, the UART has suffered an overrun error, and you do not have 'errors' set in your USE RS232 setup, so it never recovers.
Posted: Thu Jun 14, 2007 4:04 am |
what alterations do have to do for the interruption int_rda not to stop?
My program is the next:
#include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,PLL5,CPUDIV1,VREGEN
#use delay(clock = 48000000)
#include "../include\picram18F4550.h"
#include "../include\types.h"
#include "../include\lcd.c"
#include <sht.h>
int16 contagem = 0, contagem2 =0;
int8 recebido = 0;
int16 adc[4] = {0,0,0,0};
int8 canal=0;
float sht_temperatura, sht_humidade;
void actualizar_dados(void);
//Timer 1
#INT_TIMER1
void rsi_t1 (void)
if (contagem >= 500)
output_toggle(PIN_C0);
contagem = 0;
if (contagem2 >=300)
enable_interrupts(int_tbe);
contagem2 = 0;
contagem++;
contagem2++;
TMR1H = 0xF1;
TMR1L = 0x5A;
//RX interrupt
#int_RDA
void RDA_isr(void)
recebido=RCREG;
//TX interrupt
#int_TBE
void TBE_isrb(void)
TXREG = adc[0];
#INT_AD
void rsi_ad(void)
ADFM = 1;
adc[0] = (ADRESH*256) + ADRESL;
GODONE=1;
TRISD=0b00000000;
TRISB=0b00000000;
TRISC=0b11111000;
TRISA=0b11111111;
//Timer1
T1CON = 0b11110000;
TMR1H = 0xF1;
TMR1L = 0x5A;
//ADC
ADCON0=0b00000000;
ADCON1=0b00011011;
ADCON2=0b10111110;
//RS-232
SPBRG=77; //9600
BRG16=0;
BRGH=0;
SYNC=0; //assincrono
SPEN=1;
TXEN=1; //TX
RX9=0; //TX a 9bits
TX9=0; //RX a 9bits
CREN=1; //RX
SENDB=1;
TMR1IE=1;
PEIE=1;
ADIE=1;
GIE=1;
RCIE=1;
ENABLE_INTERRUPTS(INT_TBE);
TMR1ON=1;
ADON=1;
GODONE=1;
lcd_init();
sht_init();
lcd_putc('\f');
lcd_putc("Projecto:");
lcd_gotoxy(1,2);
lcd_putc("Sensor Test");
lcd_putc('\f');
while (true)
lcd_gotoxy(12,1);
printf(lcd_putc,"%d",recebido);
lcd_gotoxy(1,1);
printf(lcd_putc, "%3.1f%cC", sht_temperatura, 223);
printf(lcd_putc, "%3.1f%%", sht_humidade);
lcd_gotoxy(1,1);
| [/quote] |
Posted: Thu Jun 14, 2007 4:35 am |
Seriously, write the code again.....
If you want to do all these bitwise accesses to things, then use assembler. You have a high level language, so use it...
Add a #use RS232, get rid of all the bit operations on the transmitter and receiver registers, add 'errors' to the use RS232, which will clear the overrun error, and use getc, to fetch the character, so the extra code needed for this is called.
Your ADC code, and INT_TBE code, are the big lumps, of what is causing the problem. INT_AD, is called whenever the ADC completes a conversion. You are triggering a conversion inside the ADC code, so once this code is triggered, the routine will hardly exit. If you want repeated ADC conversions at a fast interval, use the CCP module, programmed to the required interval, and the special event trigger to operate the ADC. Otherwise this will lead to a huge bottleneck. The second problem though isthe INT_TBE. You enable it's interrupt in the timer, but do not _disable_ it, once a character has been sent. Hence it'll also keep calling repeatedly.
This code is a _mess_ I'm afraid...
