CGEngineering
SD/MMC driver - what's the correct SPI hw mode? |
Posted: Thu Jul 05, 2007 10:35 am |
As object...i can't find a mode that works (my HW is ok because mikroC routines work correctly)
thank you
regards
CG |
Posted: Thu Jul 05, 2007 10:58 am |
I have a question. If you're using MikroC, and you don't own CCS,
(and you said that) shouldn't you ask your questions on the MikroC forum ?
http://www.mikroe.com/forum/ |
CGEngineering
Posted: Fri Jul 06, 2007 4:34 am |
PCM programmer wrote: | I have a question. If you're using MikroC, and you don't own CCS,
I'm porting mikroC code using a machine that own CCS compiler (PCWH v. 4.038), in order to reproduce the same functions. If all is ok i'm going to propose a purchase of a PCWH licence, otherwise not ! I like PCWH more than mikroC, but i must solve this problem!
If i complete the project about i am working over CCS, we will buy a PCWH licence, otherwise we will buy a mikroC licence (i am using a limited demo)
So...if CCS want so sell a licence...
CG |
