PIC18C801 question
PIC18C801 question
PostPosted: Fri Jun 15, 2007 12:12 pm     Reply with quote
I am exploring the possibility of using a PIC18C801 for a somewhat more involved project and was curious as to how CCS would write/read a value from an SRAM connected to the external memory bus. I've seen others doing this but never any CCS code. I also plan on using this bus for I/O registers and would like to access those registers the same way. I am just a little confused since I realize that the PIC micros are not von Neumann architecture. I've read the datasheet about the table read/writes but I just don't know how all this would work under CCS. Does anyone have any sample code showing this?
Thank you.
PostPosted: Sun Jun 17, 2007 5:44 pm     Reply with quote
I haven't used that PIC, but here are some suggestions:
1. Read about the setup_external_memory() function in the CCS manual.
2. Look at these two driver files which call that function.
c:\program files\picc\drivers\at29c1024.c
c:\program files\picc\drivers\m68af031.c
3. Use the forum's search engine to search for:
Then read the relevant posts.
http://www.ccsinfo.com/forum/search.php
