RAM at 0x7F not defined on PIC16XXX chips
picport
PostPosted: Fri Jun 08, 2007 11:24 am     Reply with quote
Using the Chipedit.exe to see compiler definitions for PIC16FXXX family chips I see that on many models the RAM memory at 0x7F is not defined. RAM byte at 0x7F is not zeroed nor allocated for variables, so 1 byte of RAM is lost.
As an example PIC16F690 definitions indicate RAM at 0x7F as not used by the C-compiler, but (similar) PIC16F689 indeed defines memory at 0x7F as useable. Why is this? In both chips the RAM location at 0x7F exists. Is it just an error in the chip definition files?
Another related issue. On some chips the "C Scratch RAM" is allocated to 0x20 and on others to 0x77. Why this difference? Isn't the 0x77 location better since it can be accessed on all memory banks? Would the latest verson 4.040 use this bank visibility? Any comments?
PostPosted: Fri Jun 08, 2007 12:19 pm     Reply with quote
Would the latest version 4.040 use this bank visibility?
What's your current version ?
picport
PostPosted: Fri Jun 08, 2007 12:29 pm     Reply with quote
My current version is the latest one, that is 4.040. Downloaded this morning and found some earlier buggs fixed, but not the chip definitions. Any insight on 0x7F or C Scratch RAM?
PostPosted: Fri Jun 08, 2007 2:02 pm     Reply with quote
I don't have the CCS IDE, so I can't directly look at the Device data.
(You don't get the Device Editor with the command line compilers).
If you think there's a bug in the device data files, you should report it
to CCS tech support. They'll upgrade you to the next version when
they fix it (if your support has run out).
picport
PostPosted: Fri Jun 08, 2007 2:22 pm     Reply with quote
Yes, I suppose I should email CCS tech support also. It would be an excellent idea if they give you a free update for each bug you report. I find them continuously...
PostPosted: Fri Jun 08, 2007 2:31 pm     Reply with quote
I think it is their policy to let you upgrade to the version that has the
bug-fix, if you report it and if your maintenance has run out. If they
don't do it automatically, then request it.
