NewSpace
How to coding RS232 (one wire) |
Posted: Fri Jun 08, 2007 3:10 am |
Hi?
Thank you for reading.
I wanna control LANC
It's have only one line.... LANC, VCC, GND
I wanna use PIC with CCS-C...
First 4 byte is Send MSG and 4 byte is receive MSG...
But How to connection from LANC to RX / TX
and How to coding
ex>
I wanna send 0x12 0x23 0x 34 0x45 and receive mode A B C D
IF you know please teaching me connection and coding.
thank you~! _________________ Hello~?
This is South KOREA
My name is Sanghyouk Kim But Call me Nick
Sorry I'm poor English |
Posted: Fri Jun 08, 2007 4:18 am |
You will need to have a pull up resistor on the line, and use the 'FLOAT_HIGH' keyword, in #use RS232. LANC, is a Sony protocol, using 'control-L' signalling, which is a standard used on quite a few cameras, and is an open-collector drive, which this command emulates. Most cameras contain the required pull-up, but you should verify this, and I would suggest having a largish pull up present at your end of the connection, even if there is a pull up at the other end, since this will prevent the line from floating to an indeterminate state, if the camera is not present.
dyeatman
