RLScott
Using instruction timing in Assembler |
Posted: Tue Jul 10, 2007 8:44 am |
When using in-line assembler to generate precise timing with instruction timing, it is often useful to do something like this to optionally add in one more instruction cycle:
btfsc STATUS,C
goto $+1 ; one cycle or two, depending on STATUS,C
Problem 1: "$+1" is not recognized by the CCS assember (I am using an older version - perhaps the newer version does recognize it?) Of course this problem has an easy solution. Just use:
btfsc STATUS,C
goto L123
L123:
Problem 2: With #OPT set any higher than 0, the goto L123 is entirely optimized away as unnecessary, which of course breaks the intention of my code. The only work-around I can find for this is to use #OPT 0, which is global and precludes the use of any optimizations elsewhere.
Any comments?
Robert Scott
Real-Time Specialties
Ypsilanti, Michigan |
Posted: Tue Jul 10, 2007 8:56 am |
Add 'asis' to the start of your assembler block.
The 'assembler' syntax, is C like in form, and hence the 'idea' of '$' for the current PC, doesn't exist.
#asm asis
btfsc STATUS,C
goto L123
L123:
#endasm
