Pointers
aodj
Pointers
PostPosted: Thu May 31, 2007 3:53 am     Reply with quote
I'm currently dealing with some pointers and I've ended up with the following scenario:
Variable v1 is a signed int16, and contains -1 or 11111111 11111110.
Variable v2 is a signed int16 also.
signed int16 v1, v2;
v1 = -1;
v2 = &v1;
*v2 returns 255, or 00000000 11111110.
I can't work out why the pointer is being converted to an int8 and then cast back to an int16, losing the leading 8 bits.
Any ideas?
inservi
PostPosted: Thu May 31, 2007 4:00 am     Reply with quote
I do not think that a pointer can be signed ?
dro
in médio virtus
aodj
PostPosted: Thu May 31, 2007 4:02 am     Reply with quote
Even if i use it as an int16, it still loses the leading 8 bits of the data.
What I think is happening, is the contents is being cast to an int8, and then recast to an int16.
inservi
PostPosted: Thu May 31, 2007 4:25 am     Reply with quote
Witch microcontroler are you using ?
If you use a 14 bit parts, have you put the #device *=16 directive.
signed int16 v1;
int16 *v2 = &v1 ;
v1 = -1;
So *v2 is really a pointer.
v2 contain the addresses of v1.
*v2 give the value of v1;
I cannot verify that just now because i have no development board ready.
dro
in médio virtus
aodj
PostPosted: Thu May 31, 2007 4:33 am     Reply with quote
inservi wrote:
signed int16 v1;
int16 *v2 = &v1 ;
v1 = -1;
What you've written above should be right, but I'm finding that the result ends up losing the leading 8 bits, as detailed in my first post.
I'm using a 16F914, and version 4.016 of the compiler.
inservi
PostPosted: Thu May 31, 2007 7:53 am     Reply with quote
I make some test with my version 4.039 and a 18F252.
with :
signed int16 v1;
int16 *v2 = &v1 ;
v1= -1 in binary: 11111111 11111111
*v2 = 65535 in binary 11111111 11111111 OK
v1 = -2 in binary : 11111111 11111110
*v2 = 65534 in binary : 11111111 11111110 OK
v1 = 2 in binary : 00000000 0000010
*v2 = 2 in binary : 00000000 0000010 OK
There is probably an error in the version 4.016 ?
dro
in médio virtus
PostPosted: Thu May 31, 2007 11:04 am     Reply with quote
I compiled the test program shown below with PCM vs. 4.016 and
it works OK. I tested it with MPLAB simulator, with output directed
to 'UART1'. Here is the result, displayed in the Output window:
-1
FFFF
#include <16F914.h>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT
signed int16 v1;
signed int16 *v2;
v1 = -1;
v2 = &v1;
printf("%ld \n\r", *v2);
printf("%LX", *v2);
PostPosted: Thu May 31, 2007 2:41 pm     Reply with quote
I'd wonder if the fault is in the output. Remember, if you use:
printf("%d \n\r", *v2);
It'll print '255', since you are telling it the contents of'v' are an integer, not a long integer, and only the low byte will then be accessed..
aodj
PostPosted: Tue Jun 05, 2007 2:32 am     Reply with quote
After some more digging, and excessive use of the simulator, I've narrowed my problem down to one command, in so far as I can tell.
void fIncrement(signed int16 vPrimary, signed int16 vCPrimary)
   *vPrimary = *vCPrimary;
appears to pass only the lower 8 bits of the numbers. I'm using the following declaration:
fIncrement(&vOffset, &vCOffset);
The above image shows the bitpatterns I'm getting from the MPLAB simulator; note only the lower 8 bits are changing.
