peachgirl Guest
| a function for get a value with decimal using a keyboard4*4 |
Posted: Mon May 28, 2007 7:46 am |
| Code: | void gestionclavier_virgule()
int8 Bouton=0,i=0x00,j=0x00;
float k=1, data=0;
entier=0;
decimal=0;
while(Bouton != '*')
Bouton = GetBouton();
if(Bouton == '*')
i = ch_int(Bouton);
printf(lcd_putc, "%d",i);
entier = entier*10 + i;
lcd_putc('.');
while(Bouton != '!')
if(Bouton == '!')
j = ch_int(Bouton);
printf(lcd_putc, "%d",j);
k=k*0.1;
data=data+k*j;
decimal= float_int8(data);
lcd_putc('\f');
}void gestionclavier_virgule()
float k=1, data=0;
entier=0;
decimal=0;
if(Bouton == '*')
i = ch_int(Bouton);
lcd_putc('.');
if(Bouton == '!')
j = ch_int(Bouton);
k=k*0.1;
data=data+k*j;
lcd_putc('\f');
In this fuction, "entier" and "decimal" are global variable. this fonction change the value for them.
Now, I have a problem: if I want to enter for example 5, I have to enter 5.0 because of my this function.
I hope you can give me some help for that, or maybe you have a good solution for a decimal value. |
inservi
Posted: Tue May 29, 2007 4:58 am |
Your code look to be duplicated.
If i understand, you use '*' for decimal separator and '!' as 'return' key ?
The first loop is breaking only if you type '*'. I think that you need to test for 'return' in this loop too.
as :
float k=1, data=0;
entier=0;
decimal=0;
while(Bouton != '*' && Bouton != '!')
if(Bouton == '*' || Bouton == '!')
i = ch_int(Bouton);
lcd_putc('.')
if(Bouton == '!')
j = ch_int(Bouton);
k=k*0.1;
data=data+k*j;
lcd_putc('\f');
Best regards,
dro _________________ in médio virtus |
peachgirl Guest
Posted: Tue May 29, 2007 9:34 am |
Thank you very much!!!!!!
you are intelligente!!!!
the programm is very good, just change a little, I have changed
I have another question: do you know if "entier" is "signed int8", what can I do for enter a negatif value(-26.5, for example)
| inservi wrote: | Hello,
as :
float k=1, data=0;
entier=0;
decimal=0;
i = ch_int(Bouton);
if(Bouton == '*')
lcd_putc('.');
if(Bouton == '!')
j = ch_int(Bouton);
k=k*0.1;
data=data+k*j;
lcd_putc('\f');
Best regards,
dro |
inservi
Posted: Wed May 30, 2007 1:02 am |
| peachgirl wrote: |
in my case, the experiment makes more than the intelligence. (even if I am a man)
For enter a negative value, i think that you need to use a special key (other than '*' or '!' like '-' if you have in your keyboard) or, you can presses twice '*' for indicate to change the sign. Do not forget that a signed int8 can handle only +127 to -127.
sorry for my bad English (normally, I speak French)
