WinStar WG320240C
sraiderk
WinStar WG320240C
PostPosted: Wed May 30, 2007 7:32 am     Reply with quote
I have been using the WinStar WG320240C Glcd that is built in controller with SED1335. I wrote the following code. I only see the line on panel. his line is nearly the center of screen. What is wrong?
is <SED1335.c> correct drive for WinStar WG320240C?
#include <18F452.h>
#fuses NOWDT,HS, NOPUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#include <SED1335.c>
#include <graphics.c>
//#include <math.h>
   int1  warn = FALSE;
   int8  adc = 0, adc_old = 0;
   char  voltText[] = "Volts", warning[] = "Warning";
   float theta = 0;
 void displayVoltage(int adc) {
   char voltage[9];
   sprintf(voltage, "%f", (float)adc * .01960784); // Converts adc to text
   voltage[4] = '\0';                              // Limit shown digits to 3
   glcd_rect(45, 18, 69, 25, YES, OFF);            // Clear the old voltage
   glcd_text57(45, 18, voltage, 1, ON);            // Write the new voltage
char  Text1[] = "12345678", warning[] = "Warning";
//set_tris_b(0x00);
glcd_init(ON);
//output_toggle(pin_b1);
delay_ms(200);
glcd_text57(0, 0, Text1, 1, ON);        // Display text
glcd_text57(0, 20, warning, 2, ON);        // Display text
