out of rom?
ss1903
out of rom?
PostPosted: Fri Sep 21, 2007 2:46 am     Reply with quote
hi
i have a problem with 16f877A -8K word flash memory.
in my code, i got out of rom error while it used only about %42 of rom.
so i wrote a simple code how much i could use all of the rom.
#include <16F877A.h>
float a=999999;
float b=1.1;
a=a/b;
a=a/b;
a=a/b;
a=a/b;
the number of a=a/b is 75 and rom usage is %27.
after I added a=a/b
and i got out or rom error.
do you have an idea how can i achieve this problem?
PostPosted: Fri Sep 21, 2007 2:53 am     Reply with quote
How about searching the forum, before asking?...
Or even reading the manual?...
You are not running out of ROM as such, but running out of space in one 'segment'. A search on the forum, will find a full description, as well as what you can do about it. It is also detailed in the compiler manual.
ss1903
PostPosted: Fri Sep 21, 2007 4:12 am     Reply with quote
dear guest
thank for reply.
i examined compiler manual and it say you must use #separete before function. but in this code i didnt use function. there is only divison. i think this divison is built in function. so how can i use #separete in this state.
i've been searching the forum but yet i cant find the solution.
PostPosted: Fri Sep 21, 2007 7:10 am     Reply with quote
You have to split your code up....
rnielsen
PostPosted: Fri Sep 21, 2007 8:47 am     Reply with quote
Read this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=30167&
