jimcbride
DS2480 and ds2408 help appreciated |
Posted: Fri May 25, 2007 12:13 pm |
I have read data sheets. I have searched and read all pertinent posts for 1-wire. I sort of have a grasp on things but I am finally putting my pride aside and am asking for help. I am attempting a simple circuit, uC -> ds2480 -> ds2408.
I have found/modified this code as a starting point: Code: | short int onewire_init_with_error_check()
// master_reset(); //
int reset, present;
putc(0xC1); //Send a reset in command mode
reset = getc(); //Read the response byte
if((reset != 0xCD) || (reset != 0xED)) //If not right response
present = 3;
present = 4;
return present;
This always returns 3. (Using ICD watch variables, I changed the code to return a non-zero value.) I am currious why the code reads the response byte. Should there not be two bytes? The code tests for CD or ED, those are two characters, ie two bytes, right?
I have my uC uart pins connected to the ds2480. It is unclear to me looking at the data sheet if this should be a NULL connection or not. Does uC Tx connect to ds2480 Tx or Rx? I have tried both configurations and no luck so far. ( I am assuming my rs232 is working correctly. Not tested yet. No rs232 converter to talk to a PC terminal program.) |
Humberto
Posted: Fri May 25, 2007 4:00 pm |
According to the function declaration, it is expected to return a SHORT, instead you are trying
to return an INT.
In CCS, a SHORT is 1 bit wide number, is a special type used to generate very efficient code for
bit operations and I/O.
While an INT is an 8 bit number.
I guess you misunderstood the meaning of One-Wire.
The terms Tx, Rx and NULL are used widely in RS232 serial communication, they don´t
have any meaning in One-Wire communication protocol.
Search in Maxim/Dallas Semiconductor site for primary source info regarding this
propietary protocol.
http://pdfserv.maxim-ic.com/en/an/app162.pdf
Humberto |
inservi
Posted: Tue May 29, 2007 4:44 am |
Hello jimcbride,
You have to connect the TX to TX and RX to RX. It is very special that the RX of the DS2480 is in fact is TX and same to TX.
Take care about the DS2480 support 5v level rs/232. Then you cannot connect it directly to your PC rs/232.
As humberto say, correct your code by:
int reset, present;
if ((reset == 0xCD) || (reset == 0xED)) //If right response
present = true;
present = false;
return present;
Humberto,
The DS2480 is a 1-wire controlleur, with 1-wire by one side and rs/232 by the other side.
Best regards,
dro _________________ in médio virtus |
jimcbride
Posted: Tue May 29, 2007 9:29 am |
Thank you both for your respnse. Yes the code was a little messed up by me playing around trying to look at variables during code execution. I was trying to make sure where the TRUE/FALSE was comming from and more importantly, is the communication between the Pic and the DS2480 working correctly? Since I am always returning a false, I have to assume that I am not talking to the DS2480. |
inservi
Posted: Tue May 29, 2007 11:03 am |
Did you connected a 1-wire device to the DS2480 ?
dro. _________________ in médio virtus |
jimcbride
Posted: Wed May 30, 2007 9:45 am |
Yes I have a DS2408.
I think I have my clock issues figured out.
Now I think I have a new problem. Do I need a reset pulse with the DS2480? I know the one wire has a reset pulse but won't the DS2480 be different?
When I send a 0xC1 to the DS2480, I believe it is sending me back a 0xB0. The code will run once through and then wait forever to recieve additional bytes. Makes sense I guess but why am I getting back a 0xB0? I see nothing in the daasheet about that code. I get the same response with or without the DS2408 connected.
edit.. B0 was an anomally. For some reason it would show up AFTER a getc() call. It still showed up when the Tx/Rx lines were removed. Not sure how or why that was happening. After messing around and watching communications with a scope I have determined that I am running very close to 9600 baud. I am sending a valid reset command (0xC1). The DS2480 is not responding in any way. Checked all connections. Try new part? |
