Weird Loop Problem
misaeldv
Weird Loop Problem
PostPosted: Wed May 23, 2007 9:17 am     Reply with quote
Hi, I'm having a problem with my for loop, the compiler is complaining that it is an endless loop (and it is indeed since the code that I have after that loop does not execute). I tried doing a while loop and incrementing the counter inside the while loop but I keep getting the same error and the same outcome. I've looked and looked but cannot find anything wrong with it, Am I missing a library or something? Thanks in advance.
Here is my code
#include "C:\Microcontrollers\source codes\PIC16F874A\Stepper_Controller_874A.h"
#use fast_io(A)
#use fast_io(B)
#include <math.h>
   int i,j;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
   set_tris_b(0x00);    //Makes port b7-b0 function as outputs
   output_b(0x00);      //Makes all of port B outputs
   output_high(PIN_B5); //Enables the L297 stepper driver chip
   output_high(PIN_B6); //Selects current control to act on ABCD lines, instead of inhibit lines
   output_high(PIN_B1); //Selects half step operation
   output_high(PIN_B0); //Pulls reset input high so driver does not reset by mistake
   //Infinite Loop
   do{
   //i = 0;
   //j = 0;
   output_low(PIN_B7);
   output_high(PIN_B4); //slects CW rotation
   //for (i=0;i<=1050;++i){
   while(i<1050){
   //Pin B2 provides the clock (f = 1/T)
   output_high(PIN_B2);
   delay_us(1429);
   output_low(PIN_B2);
   delay_us(1429);
   i = i+1;
   }//end for CW
   output_high(PIN_B7);
   output_low(PIN_B4); //slects CCW rotation
   for (j=0;j<=1050;j++){
   ////////while(j<=1050){
   delay_us(1429);
   output_low(PIN_B2);
   delay_us(1429);
   //////j = j+1;
   }//end for CCW
   }while(true);
   //end while
kevcon
PostPosted: Wed May 23, 2007 9:21 am     Reply with quote
INTs are only 8bits wide, 0-255
declare your variable as int16 and it should work
misaeldv
PostPosted: Wed May 23, 2007 10:19 am     Reply with quote
Thanks, that did it. I guess it wasn't weird after all, just a mistake on my part.
kevcon
PostPosted: Wed May 23, 2007 11:05 am     Reply with quote
I think all us have made the same mistake at one point or another Smile
