I2C PCF8574 READ
esa
I2C PCF8574 READ
PostPosted: Mon May 21, 2007 2:46 pm     Reply with quote
I have a question about the code posted in the code forum about reading a PCF8574.
The code is ( a little simplified ) :
int IN8574(int device_addr)
int io_field;
i2c_write(0x40 | device_addr<<1 | I2CREAD);
io_field=i2c_read(); /* this byte contains the prior conversion result. */
io_field=i2c_read(0); /* returned data is big-endian (msbit first) */
i2c_stop();
return(io_field);
But, I alway have 255 for io_field.
So, I use my old code :
byte IN(byte adr)
byte datain;
I2C_start();
I2C_write((adr<<1)|0x41);
datain=I2C_read();
I2C_write(0xff);
I2C_stop();
return(datain);
And it is working.
Can someone help me to understand where is the problem ?
I use PIC16F877
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3,SLOW)
PostPosted: Mon May 21, 2007 2:54 pm     Reply with quote
int io_field;
i2c_stop();
return(io_field);
Don't simplify the code. You have left out the i2c_start() from
the driver code that was posted.
PostPosted: Mon May 21, 2007 3:20 pm     Reply with quote
Embarassed
It's working now
Thanks for the quick answer Smile
