khor Guest
problem in ADC |
Posted: Thu Mar 20, 2003 2:43 am |
i have a problem in comparing the two analog input signals, i am using Analog to digital function in pic16f877, if input_1 in higher than input_2 the pin_b7 is high, else is low.
when i comparing the input, the output is sometime showing high and low. At the thershold voltage is showing low but when i increase to 0.5V the output is high instead of low.
my coding is on below
#include <16f877.h>
#device ADC=10
#fuses XT, NOWDT, NOLVP,PUT,NOPROTECT
main()
int val0, val1;
setup_adc_ports( ALL_ANALOG);
setup_adc( ADC_CLOCK_INTERNAL);
while(true)
set_adc_channel(0);
delay_us(80);
val0=read_adc();
set_adc_channel(7);
delay_ms(80);
val1=read_adc();
if(val0 > val1)
output_high(pin_b7);
output_low(pin_b7);
Original Post ID: 12859 |
R.J.Hamlett Guest
Re: problem in ADC |
Posted: Thu Mar 20, 2003 4:10 am |
:=i have a problem in comparing the two analog input signals, i am using Analog to digital function in pic16f877, if input_1 in higher than input_2 the pin_b7 is high, else is low.
:=when i comparing the input, the output is sometime showing high and low. At the thershold voltage is showing low but when i increase to 0.5V the output is high instead of low.
:=my coding is on below
:=#include <16f877.h>
:=#device ADC=10
:=#fuses XT, NOWDT, NOLVP,PUT,NOPROTECT
:=#use delay(clock=4000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=main()
:=int val0, val1;
:=setup_adc_ports( ALL_ANALOG);
:=setup_adc( ADC_CLOCK_INTERNAL);
:=while(true)
:= set_adc_channel(0);
:= delay_us(80);
:= val0=read_adc();
:= set_adc_channel(7);
:= delay_ms(80);
:= val1=read_adc();
:=if(val0 > val1)
:=output_high(pin_b7);
:=else
:=output_low(pin_b7);
Very simple.
Remember an int, is 8bits, not 16. You are reading a 10bit value, and putting it into an 8bit store. You will then only have the low 8 bits, and the results of the comparison will be odd...
Make your storage variables into int16 types, and the comparison should be fine.
Original Post ID: 12862 |
